Question about SanDisk Sansa e250 MP3 Player
Sandisk e250 mp3 player froze up and won't turn off!
I was listening to my sansa e250.. and all of a sudden, it cut out in mid song and the screen froze... What's worse.. is that I can't turn it off.... Any suggestions???
  • ladyrat Apr 13, 2008
    MP3 FROZE UP IN MIDDLE OF SONG WONT TURN OFF OR DO ANYTHING
  • a_lemon27 Jun 16, 2008
    Mine froze on record voice and wont turn off or get off record voice
To Reboot your sansa e250 without removing batteries . Switch to hold position ( right beside headphone jack ) Press and hold menu and rec buttons at the same time untill screen resets. On my player lock up usually happens when it hits a corrupt song - try to delete and reload the culprit to minimize future lock ups. Hope this helps someone out there.
Posted on Nov 28, 2006
I am still holding the power button 1 minute and nothing!
Posted on Sep 15, 2008
I had the same problem tonight! it worked! gracias! ... the worst problems seem to always have the simple solutions lol
Junkmanfox...thanks your solution really helped! I was about to throw the stupid think in the trash!
Posted on Feb 18, 2008
Holding the power button down works
Posted on Feb 15, 2008
You just have to hold the power button until it turns off no matter how long it takes i did it and it worked just find dont take the time to unscrew everything its pointless.
Posted on Jul 08, 2007
Man this relly works this is awsem thanks
Posted on Mar 30, 2007
Nvm:) I held the power button for 15 seconds and it reset itself:) Thanks for the suggestions guys*
Posted on Dec 07, 2006
  • 3 Answers
Undo the screws in the back and take the battery out the sansa will turn off. Put the battery back in and screw the back on again. Now just turn the sansa back on and it should work perfect. (Warning Do Not Lose The Screws) I hope this advice helps.
Posted on Nov 17, 2006
Froze and won't come back on
Try connecting it to a computer if nothing Remove the back and check and see if the battery isn't fully connected push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screenand memory, Black screen Blue ring problem) and put the back on.Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Jun 29, 2010 | SanDisk Sansa e250 MP3 Player
After deleted all the songs from my sansa e260 it's just froze
hook it back up to you computer the select start,mycomputer,e250, right click on icon and format device
i had the same problem with my sansa
Aug 01, 2009 | SanDisk Sansa e250 MP3 Player
Froze when trying to delete track
Did you consider removing and re-installing the battery. THat would turn off the player so that it would unfreeze. I know its crude but its the easiest way out. After you get it working you may want to consider a firmware update from the creative bebsite to ward-off against future problems.
May 10, 2009 | SanDisk Sansa e250 MP3 Player
My sansa mp3 player is frozen!!! help me please.
Hold the on/off button for 5-20 seconds it will shut off by itself then turn it back on...
It will work.
good luck
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250r froze
yeah this happens to me all the time. just open up the back pop the battery out and back in and it doesn't kill the battery and it works just fine
Apr 15, 2008 | SanDisk Sansa e250 MP3 Player
Problems with my insignia mp3 player
A Possible solution is to charger it all the way up 'til it's full, and then try turning it on. If that doesn't work, you may have to call sansa, and/or take out the battery and put it back in. This requires a special screwdriver.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
My sansa froze up
try the reset the whole thing solution
go to recovery mode, then run the
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
i dont know if itll work but its worth a try
good luck
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
347 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
