Question about Hayward Heatpro 100,000 Digi. Thermostat Heat Pump
Corrosion on the fins of my heat pump
I have a hayward heat pro 1102. The fins are turning white and corroding. Is this a common problem?
  • bmonigle Mar 09, 2009
    Fins are covered with white powder-like substance.
    Guru:
  • 462 Answers
Do you have something close to it like a hot tub or spa or pool? If so the Chlorine is reacting with the aluminum causing it to corrode.
I suggest moving one or the other if this is the case.
If this helps you please rate me as high as you can If not please post back with an extended detail of your problem. thank you for using fix ya. Good Luck.
Posted on Mar 26, 2009
Hayward heat pro error code HI
Low water flow, its heating up to high and doesn't want to melt itself down, sounds like a pressure switch problem or corrosion build up.
Jun 01, 2013 | Pool & Spa
My 2004 Ferari 360 get over heated temp almost tuch the RED scale when i am driving in move/stop (Trafic Jam) but when drive stedy 50 MPH or more Tem was Normal 1/2 Scale about 100 C is that normal if not...
Your cooling system is operating at a marginal state. The question is why.
If the fans are working (which is good), then the system is not cooling adequately. This can be caused by many things
* low coolant level. Check for leaks.
* leaking radiator cap (common problem)
* corroded radiator fins reducing cooling. Check for dirt or other material blocking the radiator.
* sludge in the radiator (unlikely but not impossible)
* sticking thermostat.
* aged radiator hose is squashing. Hoses should be firm, not squishy
* water pump is failing. Incorrect coolant can caused pump fins to corrode
* engine is running lean, causing high operating temperature
Take the car to your mechanic and have the cooling system thoroughly checked.
Sep 16, 2011 | Ferrari 360 Modena Cars & Trucks
Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
May 27, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward Heat Pro Electric won't stay running
from the Hayward support site....
Why is my pump cutting off and on every 5-10 seconds?
  • Hayward motors are factory wired for 240 volts unless the motor is 120 volts ONLY. Check the voltage of the incoming supply power and ensure the motor is wired or can be wired for this voltage (data plate on motor will help provide voltage and wiring information). Also check for loose or badly connected wires. Contact a certified electrician for repair.
Sep 24, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Hayward Heatpro 100,000 Digi. Thermostat Heat Pump Logo
236 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
