I can't get it to out of the wall...can't find any kind of release tabs, screws, etc to allow it to slide out of cabinetry.
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
SOURCE: kenmore elite wall oven model 911.49032 code F-7
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Kenmore Elite slide in range model # C790-440732
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
