Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Re Samsung Monitor
Re i think you use tft monitor and after you plug it then lite appear and after few seconds it's gone. plz check the inverter circuit of tft monitor. and may be possible that the life of Flurocent tube is over. if you are not hardware engineer then plz tell any hardware engineer to check the your tft monitor.
thanks
what is a tft monitor? can this problem be repaired; would repair be expensive? How do I locate a suitable repair shop? Thanks for trying to help.
Guido
Pl ignore the product listed below, mine was a Syncmaster 243T
  • gdeboeck Nov 14, 2008
    Thanks. If the expense is greater than $500 the repair may not be worth it. Current models of Samsung syncMaster 25 inch run less than $500. Thanks for your advice. It was very helpful. Guido
  • 55 Answers
TFT means Thin Film Trangister. You are using LCD (liquid crystal dispaly) this means in lcd monitor use trangister on/off to create a pixel. you should give your monitor to repair at workshop for this problem. i don't know any workshop which located in your city. and about the expence it's all around rs 600 to 1000.
ok
bye
ramesh
Posted on Nov 14, 2008
How to take apart
problem is in the flash light inverter logic card. the HT power choke is gone weak. replace this and also check the supply capacitors are conected to this circuit
Jul 04, 2014 | Samsung SyncMaster T260HD flat panel TFT...
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
My Soyo 17" TFT monitor comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after about one second each...
Hi
Thank you for your query
Your monitors inverter has burnt out and will need your monitor replacing
I did not even ask for a bid for this as i dont think you should have to pay for a easy solution
Regards
Shauqat
Sep 24, 2010 | Soyo DYLM24D6 LCD Monitor
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
Oct 06, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
Pc and monitor turn on, monitor goes off after few seconds
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Sep 24, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
Screen comes on for less than one second & then goes black.
Possibly  your monitor inverter is broken, have a good look in some angel if the screen shows any picture if so then your inverter is broken. Its a common think with monitors.
Jul 20, 2009 | Dell E173FPb 17" TFT LCD Monitor
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
201 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
