Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Error code 02-803 on sony uvw 1800
Tape became stuck. removed the tape. the machine has the error code and will not work. please help
  • Anonymous Apr 07, 2009
    the same!
  • Anonymous May 02, 2009
    Someone has already mentioned the issue about the 30min SP cassette not ejecting form the deck and to look into the menu, but i tried getting to the page on the menu that says "manual eject" but i cannot get the correct page. Can anyone let me know the right path to take in the menu to get to that page, manual eject?
2 Suggested Answers
SOURCE: I have a Sony UVW
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Posted on Nov 13, 2008
Sony UVW 1800 error code 02-403 - tape is out, code won't go away
Error 02-403 is "tape slack in ff/rew". Although you were able to get the tape out, the threading ring may not have returned to the unthread position. With the power disconnected and the top of the deck off, look at the mechanism; on the right side, there is a small gray motor with a black wheel in front of it. By turning this wheel, you will be able to make the threading ring turn; turn it so the ring goes clockwise. When the ring has gone as far as it can, it will be in its unthread position, and the deck will probably work normally.
Dec 17, 2009 | Sony UVW1800 VCR
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
Mar 16, 2009 | Sony UVW1800 VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Mensaje error 02-395 on a Sony BETACAM UVW 1800
error code 02-395 points to a problem with one or both reel motors. a good technician should be able to fix this easily.
Jan 21, 2009 | Fuji M321SP Betacam Tape
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
544 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
