Question about Epson TM-H60000II Thermal Printer
Character Sequence for Slip Printing
Model M147G
What is the character sequence to get slip printing to work? I have the correct sequence to get the cash drawer to open but I can't seem to find how to get slip printing to work.
On an older TM-H6000III model, the squence in VB was:
Chr(27) & "c0" & Chr(8) & Chr(27) & "d" & Chr(6) & Chr(13)
Thanks for any help you can give!
3 Suggested Answers
SOURCE: TM-H6000III M147G vs M147J
paper jam
Posted on Dec 13, 2007
APremkumar
  • 564 Answers
SOURCE: DON'T PRINT CHQ WITH EPSON TM-H6000III
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 12, 2009
What does nul mean on the keypad?
Many older numeric keypads included a non printing character for use in the olden days when teletypes (Old style printer heads that actually traveled across a page and struck the ink ribbon with a character to create words. The Null character was a non printing character sent at the end of lines to allow the type head to return to the left edge of the page. Much later the null character is used in some programming languages and is often represented by an escape character as /0 which is the ASCII character with a value of zero. See link for full explanation.
Null character Wikipedia the free encyclopedia
Mar 15, 2015 | Computers & Internet
Slip Entries Printing out of Sequence
try to see in manual.. there should be details how to use.
Apr 26, 2008 | Timeslips 11 (TSW11RT) for PC
How do I fit the correction tape o a Smith Corona XL1500 typewriter
First, backspace to the mistaken character. You slip the correction tape in the middle of the platen where the type hits, then type the same character, pull out the correction tape, backspace and type the correct character.
Nov 28, 2014 | Smith Corona Office Equipment & Supplies
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
HOW DO YOU CHANGE THE CHARACTER PITCH
You have not specified which printer you are using.
1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
Jan 28, 2010 | Electronics - Others
Dell D600 Latitude laptop. Spanish characters when using ALT key and a # do not work. Suggestion?
Go to Programs/Accessories/System Tools and click on Character Map. You will need to do a cut and paste of the character from there. Laptop keypads don't support the Alt# sequence for inserting characters like a conventional keyboard does.
Jan 07, 2010 | Dell Computers & Internet
Hi, have most of the MX5 books but where does this car originate. chassis no.JMONA30P500100161. Its a 1996 into New Zealand from somewhere? Anybody help with this.? Thanks out there
How to read a VIN
1st character- Identifies the country in which the vehicle was manufactured.
For example: U.S.A.(1or 4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
2nd character- Identifies the manufacturer. For example; Audi(A),
BMW(B), Buick(4), Cadillac(6), Chevrolet(1), Chrysler(C), Dodge(B),
Ford(F), GM Canada(7), General Motors(G), Honda(H), Jaquar(A), Lincoln(L), Mercedes Benz(D), Mercury(M), Nissan(N), Oldsmobile(3), Pontiac(2or5), Plymouth(P), Saturn(8), Toyota(T), VW(V), Volvo(V).
3rd character- Identifies vehicle type or manufacturing division.
4th to 8th characters- VDS - Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
9th Character - The check digit "character or digit 9" in the sequence of a vehicle identification number (VIN) built beginning with model year 1981 (when the 17 character digit format was established) can best be described as identifying the VIN accuracy.
A check digit shall be part of each vin (since 1981) and shall appear in position
nine (9) of the VIN on the vehicle and on any transfer documents containing
the vin prepared by the manufacturer to be given to the first owner for purposes
other than resale. Thus, the VINs of any two vehicles manufactured within a 30
year period shall not be identical. The check digit means a single number or letter
"x" used to verify the accuracy of the transcription of the vehicle identification
number.
After all other characters in the VIN have been determined by the manufacturer
the check digit is calculated by carrying out a mathematical computation
specified. This is based on vin position, sample vin, assigned value code,
weight factor and multiply assigned value times weight factors. The values are added and the total is divided by 11. The remainder is the check digit number.
The correct numeric remainder - zero through nine (0-9) will appear.
However, if the remainder is 10 the letter "X" is used to designate the check
digit value/number.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
11th character- Identifies the assembly plant for the vehicle.
12th to 17th characters- VIS - Vehicle Identifier Section. The last 8 characters of the VIN are used for the identification a of specific vehicle. The last four characters shall always be numeric. Identifies the sequence of the vehicle for production as it rolled off the manufacturers assembly line.
Vehicle Identification Numbers (VINs) are used to uniquely identify motor vehicles. Prior to 1980 there was not an accepted standard for these numbers, so different manufacturers used different formats. Modern day VINs consist of 17 characters that do not include the letters I, O or Q.
Jan 04, 2010 | 1996 Mazda MX-5 Miata
Using ASCII commands form IBM INFOPRINT to Tally T6218
I used escape sequence: <esc>(w
this instructs the printer to use Canadian Englis font page
Nov 13, 2009 | Tally LJ Series T6218 LJ Matrix Printer
How do I find out when my car was manufactured
It's all in the VIN.
A car’s vehicle identification number (VIN) is the automotive equivalent of
human "DNA".
How to read a VIN
other than resale. Thus, the vins of any two vehicles manufactured within a 30
number.
digit value/number.
Feb 28, 2009 | 1991 Ford Explorer
Epson TM-H60000II Thermal Printer Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
