Question about HP Office Equipment & Supplies
Printer has shut down - we are unable to restart it
  • patpasser Nov 14, 2008
    I spoke with a real person who proposed this solution in a slightly different way - it worked. thanks.
    Sergeant:
    Novelist:
  • 196 Answers
Remove the power cord from its back for 10 minutes then again plug in with ON button pressed.
Posted on Nov 13, 2008
  • mmechanics Nov 13, 2008
    also tell the model number of your printer to help u more further on this issue.
    it could also happen if the power cord wire has become short and has gone faulty.also replace the power cord wire and try.also try in different electric socket at your place.
  • HP Master
  • 13,433 Answers
Hows the warranty? Unplug the printer and plug it back in. Hold down the power button for 30seconds, unplug and try again.
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Kenmore gas range ignites, begins to heat & then shuts down. It can be restarted by pressing cancel & then restarting, but then shuts down again.
You have one of two problems, either your sensor in the oven is off and the oven clock is unable to sense the temperature increase. Or the clock has lost its ability to read the sensor and shuts down. If you use a meter to read the value at room temperature should be around 1050-1070 ohms, if so replace the clock.
Good Luck
Oct 14, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
UNABLE TO CLEAN
If you have had the printer for quite awhile, it is possible that the overflow container is sensing that the cleaning pads are saturated. This means get it into the shop. An alternative is to power down, shut it off, unplug power, let it rest for a minute. Restart and try a test print and then clean.
Jan 12, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to Print error
try resetting the print jobs from your computer printer que and also resetting all jobs from the printer side also good luck
Nov 08, 2008 | Ricoh Aficio SP-C210SF Printer
Unable to install
uninstall the printer.
unplug the printer from the computer.
run the disk.
shut down the computer.
restart the computer, reconnect the printer windows
Oct 21, 2007 | Epson Stylus C46 InkJet Printer
Unable to cancel a document from printing
I have a lexmark 640 and experienced the same problem today and read similar problems but noone provided a solution. Fortunately I managed to solve the problem by cancelling the job then while it was still in print queue, shut down and restarted the computer.
This worked for me.
Roden
Oct 01, 2007 | Lexmark Z600 InkJet Printer
14 people viewed this question
Seeker5211
Seeker5211
