Question about IBM Computers & Internet
The monitor attached to my blade does not show the servers
Only Blade and E-server are on screen as devices from the blade. There are 6 serves who also should be available to chose. They are running and if I push the "select" button on a server, the screen is not jumping to the prompt of the chosen server.
Q: Where is the error ?
  • ErikTeka Nov 13, 2008
    I can't connect to the server on my terminal. The terminal only shows access tot the "Blade" and E-server
eagle338
  • 4889 Answers
SOURCE: response to constant beeping on the dell 1600sc server
Please provide me a complete list of components on your server and I will be more than happy to help..
Regards,
Sai.
Posted on Oct 07, 2008
SOURCE: veritas netbackup server 6.0
on the trouble of the multiple messages of
"emmlib_update drive runtime failed: status 328"
Let's ensure the 'device mappings file' is current on this installation?
http://support.veritas.com/docs/302599
Veritas NetBackup (tm) Server / Enterprise Server 6.0 and 6.5 Device Mappings Package for Windows Servers 1.70
Download the small 14k text file
Copy the external_types.txt file from the temporary location to C:\Program Files\VERITAS\NetBackup\var\global\
then run
C:\Program Files\VERITAS\Volmgr\bin\tpext -loadEMM
Posted on Oct 21, 2008
  • 15 Answers
SOURCE: Apache Server Port 80
This is a problem at their end, try again later. You may want to try restarting what you were doing.
Posted on Feb 14, 2009
joecoolvette
  • 5660 Answers
SOURCE: x3500 could not start (power on)
Suggest you change the power supply unit. 'Sounds' like a faulty power supply.
Suggest Electrolytic Capacitors have gone bad, in the power supply unit.
Check the link below, to see what Electrolytic Capacitors look like, and what they look like when they have failed. These capacitors don't Always show the visual signs when they fail, but most of the time they do.
I do not suggest you open the power supply unit chassis to observe closer though, as the capacitors can hold a charge for a L-O-N-G time. Sometimes weeks, or months. (Sometimes up to a year)
These capacitors are designed to slowly build a charge, then release it all at once. Should your fingers contact the terminals, of any of the larger capacitors, they could discharge their charge to You!
These could result in a bad shock or worse. (Even if your fingers contact a circuit that the capacitors are in, if your fingers complete the circuit, you'll be the recipient of the released charge)
Power supply unit unplugged from power, you can take a flashlight, and look through the ventilation holes, or slots. See if you do observe any bulging, or leaking capacitors. When they leak, there is a yellowish, or brownish ooze that comes out. It may come out of the top, or bottom of the capacitor.
At the top of the capacitor is an X, or this -> lK. It this is split open, you have a bad capacitor.
Link: http://www.capacitorlab.com/visible-failures/index.htm
Posted on Apr 19, 2009
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Dec 05, 2013 | HP ProLiant Computers & Internet
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
Trying to keep large # of hot dogs in buns warm. Do I put water in the roaster before adding the insert containing the hot dogs?
The Owner's Guide for the Rival 18qt Roaster Oven with Buffet Server is available here:
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
See Page 6 for full instructions on use as a buffet server.
You would normally fill the removable roasting pan with 5 to 6 quarts of water ot 1/2 - 3.4 full. Place in the buffet server frame and the empty serving dishes and then preheat at 350 degrees until hot.
Place hot, cooked food in the serving dishes and reduce heat to 250 degree to keep food warm. Adjust the temperature and add more hot water as necessary.
Mar 03, 2011 | Rival 18 Qt Roaster Oven with Buffet...
IBM BladeCenter HS22 (7870) not boot from cd/dvd
Go into the BIOS and change the boot devices so that the CD/DVD boot first. Also, make sure your server is seeing the correct blade and its devices. (If not check your connections.)
Good Luck
C2Solutions
Feb 24, 2011 | IBM BladeCenter HS22 (7870B4U) Server
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Have installed two new SATA HDD's, but don't show up in CMOS
Just a tip: Your OS shouldn't be on RAID. RAID is for storage.
If it is a software RAID you will need to load drivers
Even if they are disabled in boot configuration, it will show them as being attacked. You should have two areas in your BIOS/CMOS for configuring & enabling, along with setting order of boot.
Apr 15, 2010 | Vision Computer VisionMan Pentium D 830...
There are three servers (2 G5s and 1 G4) these servers share a single monitor but i don't use any kvm switch.. I manually switch the connection of the monitor to access the three servers. i use G4 most of...
Do you try disabling Screensaver feature on those two servers...might that be causing display prob, if you try pressing any key or it would show screen
But still if it is not working, Check Power saving feature for these two Server, turn off featue to turn off display and harddisk if computer is standy by for......mins
Hope it resolve issue, Best of Luck
Oct 09, 2009 | HP ProLiant DL360 G5 (457922-001) Server
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Apr 12, 2009 | Dell PowerEdge 1600SC Server
Defunct drive
You could rebuild the defunct drive with the raid program on your server.
i don't know your type and model of your server.
8488 or 8648 and the model 3 digits.
for this you need serveraid manager
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=SERV-RAID&brandind=5000008
please do not update your firmware or drivers at this point if applicable.
if rebuild of a defunct drive doesnt work you'll need to change the drive. remember in a raid 5 you need min. 3 drives.
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
