Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Error ##334 show up on display. what is it meant exectly ?
Error ##334 suddenly came up on display! tell me what should i do
    Sergeant:
  • 276 Answers
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Posted on Nov 18, 2008
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Sep 05, 2011 | Canon SmartBase MP730 All-In-One InkJet...
After start my machine is shuttingdown and then restart oredy and show me this maseege: 49 error, turn off then on.
Power off , hold down the down arrow and the cancel button and turn the power on while still holding. Keep holding until permanent storage displays
If this doesn't work you can call HP 1800-334-5144.
Mar 05, 2011 | HP LaserJet M1522nf Multifunction Printer...
Printer continous initialise no error coming & 5 arrows appear on display panel
You have to be a little bit more specific next time, we have 2 possible scenarios:
A) The printer freezes while initializing with some arrows
B) Blank display / No display
Both are usualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44 begin_of_the_skype_highlighting 1 800 334 51 44 end_of_the_skype_highlighting) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M1522NF will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jul 21, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
Connon mp730error ##334
#334 is an eprom error and if turning on and off does not reset it, you have something going on with the main logic board.
http://printer1.blogspot.com/2009/01/canon-multipass-mp730-service-manual.html
Above is a service and repair manual this will assist you to troubleshoot and hopefully repair, although I fear with this type of fault, it needs to be returned to the factory.
May 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
That message indicates that you did not input during the diagnostic that you could see the test. If the system is running normally, then the error can be ignored.
Dec 28, 2009 | Dell Inspiron 6000 Notebook
I m not able to understand what is exectly router is and what is swtch
HUB, a simple mutiple connector, that connects more network devices.
Switch a network connector that connects multiple devices performing a simple data flow control.
Router: This is a computer (yes there is a computer inside your router) that assign to each device an unique identificative on local network, called the IP address.
Devices communication on the network is routed to the best path using determined alghorithm.
Dec 05, 2008 | Zyxel Prestige 334 Router
Printer error
how to fix mp390 printer error ##334
Aug 11, 2008 | Office Equipment & Supplies
I have a Maytag A/C window unit model number M6Y14F2B , 14000 BTU and on the display screen its showing a error code of EE. I would like to know what this means and can it be fixed.
Why should I tell you how I fixed the problem for free if you can't even tell me how to solve this problem for free. I just wanted to know what the error code meant and if it can be fixed or is the unit junk.
Jul 28, 2008 | Maytag Heating & Cooling
Printer
#334 is an eprom error, try turning it on and off to reset it, if it doesn't work there might be a problem with the main logic board.
Apr 12, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
348 people viewed this question
old marine
old marine
