Question about Canon Pixma iP6600D InkJet Photo Printer
Error 5100 - what does this mean?
I've just replaced the cartridges on my Canon Pixma ip6600D, and it is printing with a shadow, as if the heads are not aligned. I have done the auto head align and manual head align, but it prints out one page before displaying "Error 5100" - does anyone know what this is, and more importantly how I can fix it please? Grateful for any help. Thanks.
  • 3 more comments
  • Lucy Clemson Nov 21, 2006
    Hi Dude,
    Thanks a lot for such a thorough and detailed response, it's much appreciated. We've followed your advice but things aren't looking good, so the pixma is going to have to go in for a service. It was only bought in April, so very disappointing. Thanks once again for your help, I'm very grateful in any case.
    Luza
  • Anonymous Dec 21, 2007
    Thank you Dude ... here I am over a year later with the same problem ... I tried switching it on and off first and now it makes a graunching noise so I have had to give up till I can get a technician.
    It was great to find the info./explanation there thanks Dude.
    Margaret
  • Anonymous Jan 04, 2008
    printing is not being done a service error comes 5100 yellow light green light simultaniously seen. new cartige inserted. Pl. find the solution
  • jlmusna Apr 27, 2008
    Problem started with (1) a continual error message that I had two of the same magenta cartridges installed (I didn't). At first, by opening and closing the top of the printer, the message would usually go away (eventually). Also, I replaced the magenta cartridge twice but the message continued. Finally, I used the "deep cleaning" function and replaced the magenta again and it worked for about 6 weeks. (No error code displayed at any time.) (2) Then, in the middle of printing, "Error 5100" displayed for the first time. All cartridges were removed and a through inspection and cleaning was done inside (no loose or missing parts inside). The printer makes a "griding" noise when the cartridge tray (empty or full) goes to the extreme left side. I assume the the second problem is a timing belt problem. I think that the printer is history.
  • Anonymous Aug 07, 2008
    Just reinstall you Printer Software and than install it again!
    This is the "error 5100"
  • 47 Answers
Hi Luza, A 5100 error is a carriage problem. That means it could be the code strip, carriage assembly or logic board. First make sure nothing is keeping the print head from moving all the way across the printer. If the smallest thing blocks the head from going all the way across it will generate this error. You'll want to look hard for ANY obstructions anywhere. Throughly check the gears and rollers for obstructions too. Second the code strip (or timing strip) is the 1/4 inch plastic strip that runs across the printer and through the head carriage. It's got supports on both sides. If becomes dislodged it will generate this error. (it's got a tesnsion spring on one end) I have a feeling that is your problem. That somehow when you replaced the cartridges you may have dislodged the code strip. That might account for not being able to correctly align the print head too. Make sure it's straight, level and secure. Also make sure it's not dirty. Grease or dirt on the code strip can generate a 5100 error. You can clean it with a damp cloth (water) but be careful if your going to remove it from it's anchors. You can try cleaning the steele bar that the carriage runs across as well, but you'll have to lube it back up with a cloth dampened with some 3 in 1 oil or a light machine oil. If none of that works and your ABSOLUTLY SURE there is nothing in there blocking the printer then it must be either the carriage assembly or logic board. If either is the problem you're going to need service on the unit or a new printer. I hope this helps. Please let me know how you make out, Dude
Posted on Nov 17, 2006
  • The Dude
    The Dude Nov 21, 2006
    Hi Luza,
    You're very welcome, I only wish it had helped!
    There was a time when ALL my good friends owned Compaq printers and if I saw another "Error 5100"...
    If you think of it when you get the printer back I'd be interested to know what the problem was. It might help me help someone else! ;-)
    If you ever need any other help just stop back, there are lots of helpful folks here!
    Dude
    Guru:
  • 377 Answers
Hi Luza,
I hope this helps.
Dude
cropp
Posted on Sep 26, 2008
I solved my jlmusna, 4/27/08 problem (Error 5100) with an extremely through and careful cleaning of all of the areas where any printer ink was found inside the computer (even the printer cartridge areas). This took about an hour using denatured alcohol, clean, soft cloths and Q-tips. Once all of the ink was cleared off, the printer worked as it should. I haven't had any problem (or Error 5100) since. I didn,t have to reload my printer softeware.
Posted on Oct 01, 2008
I solved my jimusna, April 27, 2008 problem shown above (Error 5100) with an extremely through and careful cleaning of all of the areas where printer ink was found inside the printer. Once all of the ink was cleaned off, the printer worked as it should. I didn't have to reload my printer software and I haven't had a problem since.
Canon pixma mx432 printer error 5100
I have a Canon mx432 that was new, but gave me a 5100 message that I couldn't clear. I cleaned the transparent belt that guides the print cartridges, and now it works great. I spent hours on it until I cleaned that strip - - nothing else worked
Sep 12, 2012 | Canon Pixma MX420 All-In-One Printer
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
HI I HAVE A CANON MX 320 MULTIFUCTION MACHINE, THE INK CARTRIDGES HAVE BEEN REPLACED BUT THE SCREEN KEEPS SAYING PRINTER ERROR HAS OCCURED 5100, HAT DO I DO TO FIX
5100 error means a Carriage Home Position Error.
Just make sure you remove the plastic strip covering the print head and the contact copper of the ink cartridge before you insert it to the cartridge holder.
Other possible solutions is that the cartridge is not properly seated on the carriage or cartridge holder. Once it is not properly seated the cover of the cartridge holder usually hit when it moves.
You may also clean the contact copper of the ink cartridge using an soft cloth or cotton moistened with alcohol to clean the surface. Please avoid touching the surface by your fingers.
Jun 23, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma iP6600D - ink problems
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Oct 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
2,610 people viewed this question
old marine
old marine
