PRINTER NEEDS CLEANING - Computers & Internet
How to get my printer clean
Posted on Dec 31, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
You can run your printer head cleaning program by going to printers, right click on your printer, select properties, and look for printing pref then look for any maintenance selection. If that doesn't help printers are very inexpensive these days so I'd go get a new one.
Hope this helps,
Henry
Posted on Nov 13, 2008
After cleaning printhead printer says printhead needs cleaning
If that's the case, the printhead will need to be replaced. If your printer is still under warranty, you can contact our technical support team to have the printhead replaced. If not, you can purchase a printhead online at http://bit.ly/IZYhWo.
Also, make sure that you're using genuine Lexmark cartridges. Refilled/remanufactured cartridges might damage your printhead.
Oct 28, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Errors= head cleaning fault. position fault
head cleaning fault, you need to remove the option for head cleaning.
The position fault may be due to either a wrong label size, wrong detecting sensor selection or your printer sensors needs callibaration
Aug 15, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
Hp psc 1100/1200 series All-in-ONE INK JET PRINTER PAPER WONT FEED INTO PRINTER
Try cleaning rollers and everything you can get to on paper path. Use hand wipes, or baby wipes, etc
It sounds like the path needs cleaning.
Jan 04, 2011 | HP inkjet 2280 Printer
COLOR IS NOT PRINTING VERY GOOD
There are many reasons for this problem.but some very common possibilities are as follows:--- 1) The color cartridge in the printer is near to empty.in this case replace the cartridge and check out. 2) The other reason is that color cartridge is not empty but the color in it is got dried up .In this case also the cartridge needs to be replaced. 3) Many times this problem occurs after the cartridge is refilled.or you are using re-cycled cartridges instead of original cartridges. BUT if you are using original Epson cartridge,the cartridge is not empty and the ink is is not dried up.Still you have this problem then,its the problem of the print head of the cartridge.In the printer where you insert the cartridge below that there is a print-head.In the print-head there are many tiny holes.From this holes the ink passes for printing on paper.But if this holes are blocked then ink will not pass even from the new cartridge.In this case the print head needs cleaning.From the PC in printer properties there is a option called"CLEAN THE PRINT CARTRIDGES" but this is automatic cleaning.But if the ink is jammed very hard then this automatic cleaning will not help.The print head will require manual cleaning.And for that the printer needs to be opened and print head needs to be removed.If the printer is under warranty then its advisable to get the print head cleaned by Epson service center but if its out of warranty then you get it done by local printer repair tech.But if the ink is stuck up very hard then the print head needs to be replaced. Thanks. you can rate this solution and show your appreciation.
May 17, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Printer leaving ink marks on paper
My expert opinon this printer needs to be cleaned inside, A stroung maintaince will do such as a cleaning kit, cleaning rollers and feeder and what not if that does nto work clean the fuser.
Nov 24, 2009 | HP LaserJet 2420 Printer
Print head needs a good cleaning,deep cleaning just won't do it. jrc
You do not have 2 do the cleaning of printhead often ..Printer has a self maintenance process which automatically clean the printhead also.Yeah,u do not have to take the printhead out and clean it with a cloth or alcohol as it can damage the printhead as well as printer.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have vertical marks printing on my document
This failure is caused by the drum in the printer. I believe it needs to be replaced. Perhaps some cleaning will fix the issue. If after cleaning the lines still there, that means the drum is scratched and needs replacement.
Check the user manual for how long the drum should last or when it should be replaced.
Aug 05, 2009 | Epson Aculaser C1100 Printer
Pictures coming out red
Bad ribbon in your printer or ink cartridge needs to be replace. Also cleaning your printer always helps. Don't forget to check your manual for cleaning guide line.
Jul 03, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
Clean prinnter massage
The Zebra printer displays the Clean Printer message when the printer prints a 1000 cards.
This is to maintain printer and ensure good print quality.
The way to clear the message is to get cleaning cards and run a cleaning routine.
The CD that comes with the printer will run a video showing how to run the cleaning cards through the printer. Printer needs 2 unique cleaning cards (1 short & 1 Long)
Feb 01, 2009 | Zebra P330i Thermal Card Printer
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
