Question about Sharp Televison & Video
BD-HP21U | BD-HP50U Firmware Version PN8091201 For some reason it gives me an error message on my player when i try to load it on. Im not the only one having this problem. thanks
I had similar problems with the firmware upgrade. I had to do a "System Reset" on my player (in Settings menu), and after that, the firmware went on without a problem. It played Casino Royale fine after that (as well as Dark Knight). It still will not play Prince Caspian though. I have heard that an update from Sharp is due to be released any day now to fix the problems with Caspian.
Posted on Jan 16, 2009
Samsung bd-c6900 xaa dvd player freezes on 3d prometheus movie in same spot at scene 20
Report the error to Samsung support. There is an ongoing problem with the firmware. Make sure you have updated to the most recent firmware version 1025.0 that was released this month. There are still unresolved problems with the new firmware release though. Many movies will fail to load and other will load and play but will skip/freeze during playback. This is related to the anti-piracy features on the Blu-Ray that the player can not properly handle.
Mar 30, 2013 | Samsung BD-C6900 Blu-ray 3D Player
Im trying to upgrade my firmware on my samsung blue ray player but I keep getting a message saying that I have data error. I tried differnt files, usb flash drive, ethernet through my laptop, and burning...
Don't upgrade the firmware on your Samsung BD-P1600. The firmware from Samsung is faulty and will most likely crashh your machine, Permanently !!!. I made that mistake last night. Now I have no Video output to my T.V. from any of the video outputs on the blu-ray player. Also the unit turns on but will only display LOAD , OPEN, CLOSE, ON, OFF... Nothing Works now.. This is apparently a common issue and there are several forums discussing this problem.. No fix that I have found !!
Feb 09, 2011 | Samsung BD-P1600 Blu-ray Disc Player
I am seeking software update for my BD-HP210U Blu-Ray Player.
You should have an option in the menu which says Update Firmware, failing that the Sharp website will have the update which can be burnt to disc and inserted into your player.
May 30, 2010 | Sharp BD-HP21U Blu-Ray Player
Bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Apr 26, 2010 | Sharp BD-HP21U Blu-Ray Player
My blue ray bd 21 wont play some movies im told
My advice is to contact the company that makes the unit and ask them if it requires an upgrade. Let me know what they say so i may advise further. Thanks.
Apr 16, 2010 | Sharp BD-HP21U Blu-Ray Player
I have a sharp bd-hp21u model blu-ray disc player. I am trying to use a brand new blu-ray disc. However, it will only play for 17 seconds and goes blank. What shd I do? It will play regualr dvd's.
Verify version of the firmware, if it is older then PN9062300, you will have to upgrade it. Newer version of the firmware can be found here. For instruction on upgrade procedure refer to the owner's manual.
Dec 28, 2009 | Sharp BD-HP21U Blu-Ray Player
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
Jul 16, 2009 | Sharp AQUOS Blu-ray Disc Player
Televison & Video Logo
626 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
