Question about Acer Aspire 5000 Notebook
Acer Aspire 5000 series that keeps unexpectly shutting
I have had this laptop for 3 years and it's been working fine until about 3 months ago. It started by unexpectedly shutting down and now it also freezes with increasing frequency.
When starting up, it always now defaults to a disk check which states that there are 12 bad sectors.
I've tried cleaning up / deleting all files, doing a defrag, and booting with the system recovery disk but to no avail.
What should I do?
  • Acer Master
  • 4,806 Answers
The hard drives ready for failing, back up everything now to avoid loosing data, run chkdsk /f this command will scan the disk for any problems and try to fix any bad sectors, if this doesn't work i'd think about buying a new hard drive
Posted on Nov 13, 2008
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Acer Aspire 5630 Laptop Unexpectedly Shuts Down
r u allowing the fan to intake air to cool down cooldown
Apr 28, 2010 | Acer Aspire 5630 Notebook
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
My acer aspire 3680 shuts down unexpectedly only when the battery is plugged in. When I remove the battery it works fine. Is the problem with the battery or something else in my computer?
It is the battery. It is damaged, and because of that it changes the voltage of the AC. the best solution is to replace it with a new one, but until then, work without it, or you might have fried lap top
Nov 14, 2009 | Acer Aspire 3680 Laptop
Shuts off unexpectedly
Hi there.
Because the machine is only one month old i would recommend that you take advantage of the manufacturers warranty and send it in for repair, it won't cost you anything to do this as this sounds like a serious hardware problem or failure which is not of your doing.
Telling you to open the laptop will only void your warranty so this is not recommended.
Your computer will only be away for a week or so and i know it could be a pain not having it there, but for peace of mind this is the correct procedure.
Good luck and thanks for using FixYa!!
May 25, 2009 | Acer Aspire 3680 Laptop
Component missing Acer aspire 3620
Hey,
The vga board on this laptop heats up very easyly and the heatsink is uselessly small. Video may fail withing 12 months. I would recommend another laptop model, this series 3xxx and 15xx have cooling issues and parts fail often. Not much you can do about the problem.
Thanks,
Ekse
Aug 19, 2008 | Acer Aspire 3000 Notebook
Laptop goes off
If a computer shuts itself down suddenly after 10-15 minutes it's usually down to oveheating. clean the filters and ensure that there is good airflow around the computer when you use it. you can keep an eye on temperature and control your fans with this program
http://www.almico.com/sfdownload.php
you might need to buy a laptop cooler like this
http://www.amazon.com/Targus-PA248U-Notebook-Chill-Pad/dp/B0000AKA8Y/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1204562271&sr=8-1
which sits underneath it and blows cool air in
Mar 03, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5000 series laptop
Just check in the power options that anything is not set to shutdown if idle like the hard drive. it sounds really to be processor overheating problem, just check around the side and underside vents for any blockage. Does your fan appear to cut in at any point and stay on or not come on at all, as these things ay be a clue to the problem if it's the processor overheating and shutting down.
Apr 19, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5000 Notebook Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
