Auto Switch does not work for HDMI inputs
I have Panasonic TH-42PZ85E Plasma TV. When connecting with SCART, it automatically selects the input when the connected device (VCR, Sat Receiver, etc.) turned on; but when connecting with HDMI, auto selection does not work.
  • 1 more comment
  • bulentya Nov 20, 2008
    I just heard from Panasonic that they don't have this option for HDMI inputs. It is so strange that newer technology does not have options old ones have.
  • foxsat Mar 08, 2009
    Humax FoxsatHD, HDMI switching result
    Hi everybody,
    In my last threads, I more or less accused Humax of manufactoring a stb which couldn't auto switch.
    Since then, I have tried 3 different Panasonic TV's : my French SECAM model N° TH42PZ800E,my UK PAL TV : Panasonic TH37PX70B, another Panasonic UK TV (courtesy of John Lewis) TH42PZ800B.
    The Humax HD foxsat auto switched perfectly on the two UK models but refused to auto switch with my TV set in France.
    Can anyone draw any conclusions apart from staying in Surrey all the time?
    Do you think it's worth buying this auto switch for my French TV?
  • Anonymous Mar 15, 2014
    Hi, I have a Panasonic Plasma TV model number TH-42PX70A and the HDMI connections have stopped working, possibly after a lightning storm hit Sydney two weeks ago. Can someone suggest a way to get the connections working again please?
Try this:
Posted on May 17, 2009
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Dec 07, 2007 | Televison & Video
I have an older Panasonic TH-50PHD6 Plasma TV would like to add HDMI, any suggestions?
You can get HDMI switch which will allow several input to be selected to go to 1 output for little money.
Look on ebay.
Please dont forget to vote if you liked my answer
Feb 08, 2011 | Panasonic TH-50PHD6UY 50 in. HDTV-Ready...
Trouble trying to connect my dvd player and set it up to my new 42 " L cd lost instructions!
You will need to determine if your DVD player is HDMI or Scart. If you connect it via a scart lead, then it should automatically turn on when you power it up, if not it will be located on your tv under the appropriate source/input label, ie AV1/AV2, or SCART.
If you are using a HDMI lead, then you will have to turn it over yourself, as HDMI does not support switching control. To do this, locate the input button on your remote (sometimes labled source) and press it until you can select the correct HDMI input using either the directional buttons, or by repeatedly pressing the input button.
Hope this helps
Jan 03, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Panasonic tv connected to Dish. How do I switch input to watch DVD's? The remote that I have for the tv doesn't have an input button.
As the sat box got 2 scarts connector on back, or as tv got 2 scart connectors on it if so connect output from dvd to scart connector on sat box or tv when play is selected on dvd tv should auto switch a-v input (21pin scart lead will be required
regards windyhouse
Mar 07, 2010 | Televison & Video
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
There is an abnormal AC voltage entering the TV from one of the input cables or AC
Follow the Testing procedure to determine if there is a problem external to the product.
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Televison & Video Logo
1,482 people viewed this question
Top Televison & Video Experts
