Question about Olympus Stylus 600 Digital Camera
How to use the Zoom
Digital camera does not want to zoom
    President:
  • 919 Answers
I assume you mean when pressing the W or T buttons the zoom feature does not work. Try to reset the camera to the factory default settings and this should enable the zoom feature to work again. To do this go to Ok button and then to Mode Menu - then to Setup tab and then right arrow to Reset. hit the right arrow and you will see Reset Yes or No. Highlight Yes and press Ok. Camera should be in factory settings and zoom option will function.
Posted on Dec 15, 2008
How do I turn on the Digital Zoom?
First, the digital zoom feature is not available in AUTO mode.
If you're not in AUTO mode, is the digital zoom turned on in the menu? Check the "DIGITAL ZOOM" entry in the Shooting menu.
Jul 23, 2010 | Olympus Camedia C-700 Ultra Zoom Digital...
Just purchased it from bid tv it has 4xdigital zoom would i have been better to get optical zoom instead this is my first camera
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
Sep 25, 2009 | Vivitar 7.0MP Camera Digital Camera with...
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Super Zoom
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Telephoto zoom
The D-565 camera has a 4x digital zoom, in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Telephoto zoom
The D-575 Zoom has a 3x digital zoom and a 3.3x digital zoom, which gives you a total zoom of 10x. Use the shooting mode menu to activate the digital zoom feature. The D-575 camera has a 3.3 digital zoom, which gives you a total of 10x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Differences between Optical Zoom and Digital Zoom
When you change the focal length of a zoom lens, the subject is magnified. Optical zoom replicates the zoom of a 35mm camera. Digital zoom takes a portion of the image's data and displays it at full size, producing a magnification of the original image, similar to the effect of using a telephoto lens. However, the process is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Olympus Stylus 600 Digital Camera Logo
207 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
