Question about HP LaserJet 1500L Printer
HP Laserjet 1500 Color, Print out Blank
I Have HP Laserjet 1500 Color Printer in the Office, but Print out is BLANK. About Toner Catridge ( Black,Cyan,Magenta,Yellow ) + Imaging Drum, All News. Try Cleaning the Printer But still Blank for Print out. What trouble about? and what must I do,  may it's any trouble to Hardware like Laser (Lens) or others part?  I need solution, Please.  Sorry, I can not speak english very well. but I wish you understand what about my Problem. Thanks.
  • mrvideo_2000 Jan 24, 2009
    Printed pages come out blank, all tests say the printer is functioning properly. Is there an inexpensive hardware fix?
    Novelist:
  • 125 Answers
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Posted on Jan 10, 2009
My printer Hp Color laserjet 2840 is given an Incorrect yellow initially, after i bought the catridge it is telling me of 52.4 error how to go about it.
Take the cartridge out and reseat it. If you bought a compatible toner I would order an OEM HP brand toner. These machines don't work well with compatibles.
Jan 20, 2017 | HP LaserJet 2840 Printer
Printer Printing blank pages
Does it print at all? Have you tried a demo print? menu->information->print demo
Is it printing additional blank pages are all pages blank?
The first thing to check would be the toner.
Try printing out the supply status page (menu->information->print suppies status).
You could also try diagnostics-> PQ troubleshoot.
John
Oct 10, 2011 | HP Color LaserJet 5550hdn Printer
HP 1320 Prints Blank Pages
HP 1320 Prints Blank Pages Problem with the HP LaserJet 1320 Printer
Sep 03, 2011 | HP LaserJet 1320 Printer
The HP 4600 printer prints out ok and then leaves blank
Inspect the transfer belt for dents or dips (on the door when opened up to see the toner cartridges. big black film.) if it looks good give more info like is there a pattern on the print outs.
Jan 05, 2010 | HP LaserJet 4600dn Color Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Printer prints blank pages.
 it a transfer belt issue....there is a test you can perform to confirm. When the first page comes out of the printer blank, open and close the back cover. If the next page comes out with print on it, then the transfer belt is the issue. One thing you can try is take the old belt down to a service station with a good air compressor and then use the air compressor to blow the heck out of the belt until no more toner comes out.
Mar 04, 2009 | HP Color LaserJet 4550n Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 1500L Printer Logo
1,090 people viewed this question
Seeker5211
Seeker5211
