So i canot see any thing in my monitor, the screen is black
There are a number of issues that causes this to happen.firstly check to make sure the machine is getting power, if it is and it all lights up turn the machine off remove the memory modules (memory is located on the underside of the machine) get a standard eraser and clean the brass pins with the rubber eraser, put the memory modules back in and that usually works.
If you still have problems with the monitor then chances are its the inverter (backlight) or processor
hope this helps
regards
how can i solve this problem though i can't see anything on the monitor
