Question about Teac PLD2000 System
System not starting properly
I have been noticing freezes lately when I am playing a DVD. When this happens, the DVD freezes and all functions on the remote as well as the player are lost. I would turn off the power manually and wait for some time to pass. Most of the time, this fixes the problem. Sometimes, when I turn back on the player I would see some gibberish (like a half lit display showing some ?matrix? style letters) on the display and the player does not start up properly. When this happens, I would allow for more time for the player to be turned off and it does the trick until now. The last time the player froze, it was about 3 days ago. And every time I have tried to turn it back on, I would get the same gibberish on the display and the player is non-responsive to any command. It has never taken this long before for the player to return to normal. Do you think this is an overheating issue? Any advice would be greatly appreciated.
  • oscar wilde Nov 16, 2006
    Upon further examination, I actually do have some controls of the remote like going into setup, turning volume up and down, etc. But the player seems to be stuck in DVD mode but won't play or eject the DVD inside. And when I try to change the player to Aux or Radio mode, the player just turns off.
    I think that if I can somehow get the DVD tray to open and take the DVD out, I might be alright. Does anyone know how I can do this manually?
I had the same issue... SOLVED
If you switch on the system touch the low-frequency caps (3200 uF (25V)) you will notice the caps are hot. This is caused by the age of the system because the cap's electrolyte is aged and caps loose insulating and start being utilizator. In this case all the egress 6V stadium is overloaded and the IC (7806) overheat.
In my case one of the caps was unsoldered... (extracurrent/heat???) so I have replaced the caps and mounted a little fan (12V - 6cm x 0.8 cm) in the case just near 7806 heatsink, this fan pull the hot air from the chassis ant put it out.
Now the system seems running well.
Sorry for my poor english
Bruno from Rome
Posted on Oct 28, 2007
    Genius:
  • 1,074 Answers
I do not have an schematic for this item but from your complaint you must have the prossessor change.and your set will return to normal.WHAT HAPPEN IS THAT WHEN THE CURRENT PASSES THROUGH THE IC IT BECOMESW HOT CAUSING IT TO FAIL.
Posted on Jan 22, 2007
I have a Philips HTS5550 home theater. The dvd machine has of late been displaying a "No disc error" when i insert a dvd in the machine to play. I have already tried using the cleaning kit. What might
if there's no flashing red light on lens?.. the ribbon connector of lens is not properly connect, or change it if you notice that it has lines cracked. the bad performance of the disk spinning motor is also causing why was your unit displaying "no disc" error.
Aug 04, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Starting play dvd will start to play then screen goes blue computer frozen must power down to un freeze
does this happen only when you play dvd? bluescree usually pertians to Operating system issue, so i suggest you back up your files as early as now, and try reinstalling your OS. If it still wont work, you may need to replace your hard drive.
Apr 08, 2010 | HP Pavilion dv7-1130us laptop
IPod freezes during use
The best thing to do wuld be to first, back up all of the stuff on your ipod, and the restore it back to factory setting through itunes. After that, you can put all of your files back on the ipod and it should function normally.
Dec 30, 2009 | Apple iPod MA446LL/A MP3 Player
The player either freezes completely or pixelates during playback
I think the problem is for this the disc may be damaged. Or dont use copies this freezez and ruines the system, there may be a microchip problem i sugest return it and ask for compesasatin
Dec 21, 2009 | Samsung BD-P1500 Blu-Ray Player
My xbox 360 stopped loading
Heat needs to be removed from your xbox for it to function properly. If you are starting to see random lockups and odd artifacts in graphics it may be time to clean out your console. Keep in mind that in game lockups can also be caused by DVD issues but if can stick your xbox in a cold place and notice that this gives you stable play time then clean it of all dust. I am talking about taking it apart and giving it a good cleaning. If this does not help try a aftermarket fan.
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 16, 2009 | Microsoft Xbox 360 Console
Blueray dvd does not play the new hulk b.d. movie
Same here going to try and install new drivers
Oct 24, 2008 | Televison & Video
Dvd player frequently pauses or freezes while trying to play audio cd's
You tried cleaning the lens right?  That's the first thing I would do. You may have to actually open up the unit and use some windex on a cotton swap to clean the lens. Be very careful not to overwet the cotton swab. Use the other end of the swab to dry the lens.
The red wavelength of light from the laser might not be getting through the lens properly, which is used for the Audio CDs, where the higher frequency laser is used for the DVD material.
Mike
Oct 31, 2007 | Sony DVP-NS55P DVD Player
System seems to have crashed
there is no way you can restore them consider the pictures lost you will have to delete them in order that your set wil function properly.
Mar 11, 2007 | Philips DVDR520H DVD Player/HDD
Teac PLD2000 System Logo
63 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
