Question about Cuisinart Coffeemakers
COD 4000 coffemaker is not brewing a full pot.
My coffemaker stops brewing after 1 or 2 cups. It will not brew a full pot at a time. I have to keep turning it off and on to finally get enought coffee and it still doesn't make a full 12 cups. I have tried cleaning it with a decalification cleaner as well as a vinegar and water solution, but if it won't brew the whole pot it can't fully clean it. I'm about ready to throw it out the door!
  • 4 more comments
  • jwerner Nov 15, 2008
    I have the same problem, but mine is a 10 cup coffee maker. Can anyone help?
  • kirksmom Nov 17, 2008
    I have tried it both ways , pushing the 1-4 cup button and not , and it still won't work. Maybe the program is messed up.
  • Anonymous Dec 24, 2008
    I have the same issue. I will attempt to make a full pot (10 cups) of coffee and it will brew only 1-2 cups then shut off. I try to turn the grinder off and restart the coffee pot then it will **** 1-2 more cups of water through the coffee grinds...this continues until the 10 cups of coffee is finally brewed! I am willing to try anything to fix my coffee pot. Please help!
  • coffeecoffee Feb 23, 2009
    I have the 10 cup COD coffeemaker and have been experiencing the same shut off problem during what should be one full brewing cycle. Also, the last time I cleaned it with decal powder (of course, I mixed it with water to get the correct solution), something happened to the programing and now I have to push the 1-4 cup option to get it to brew a whole 10 cup pot. If I don't push that option, I get exactly 4 cups. It's backwards. When I got online to research this issue I only typed in "coffee maker stops brewing during cycle" on the search engine window and the first link I got was this one about the COD 4000. Is this coffeemaker a dud?
  • iguerrero200 Feb 27, 2009
    I have the same problem with my cuisinart coffemaker. Is not brewing the full pot. I all ready cleaned and I still having tghe same issue
  • Anonymous Mar 17, 2014
    pot is ready to brew with cup in place-push button and no water comes out-pot show water is hot
I had the same problem, its the screen in the clear water container is plugged...i sprayed mine out and now i have no problems. it was plugged with coffee grounds.
Posted on Jan 07, 2009
  • 4 Answers
This is a design problem on all of these Grind and Brew Pots. The problem lies in lower bulb which touches the top of the carafe. The bulb does not get fully pushed in, allowing the water to drain at a sufficient rate. The quickest fix is to lift the carafe approx. 1/8". I threw a 2 1/2" Diameter washer which i purchased at Lowes (appox. 1/8" thick) into the recess where the carafe stands. By doing this I boosted the carafe up, which pressed the bulb all the way in, which now lets the water drain through the coffee and filter quicker, which means no more overflows... Problem solved.
Posted on Sep 21, 2009
I have also had a problem with the twelve cup version of this coffee maker. After a little over a year of use, the water ball would stick occasionally, and then, suddenly, it was taking about 45 minutes for the brew cycle to even begin. I thought the heating element was failing. Then I discovered that the manufacturer recommends doing a cleaning cycle after every thirty coffee cycles - a bit more often then my practice. A double cleaning and rinsing (with two store bought brands of cleaner) actually corrected the problem... Hope this is all that is wrong in your case.
Posted on Sep 05, 2009
  • 4 Answers
You do realise that this coffee maker is a programmable appliance?
Are you pushing the 1-4 button by mistake?
Posted on Nov 15, 2008
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
Cuisinart Coffeemaker Decalcification Process
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Does not brew a full pot anymore.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart Coffeemakers Logo
793 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
