Question about Canon Office Equipment & Supplies
Constantly getting error code E3 on my Pixma MP150 multi-function printer. Have checked inside repeatedly and can see no paper jam
  • TallAndy Nov 15, 2008
    Looks like I may have a leaf in the paper path! Some time soon I must try to work out how to remove it. Thanks for your help, at least I now know where to look!
  • Texcoast Mar 03, 2009
    I have the same problem - E3 error and no paper stuck. I used a small screwdriver to push down the toggle & other parts where the paper feed rollers are but no luck. I took the screws off the back but couldn't figure out how to take the back panel off to get to the roller assembly. It appears that both sides come off but I stopped for fear I would have the printer in pieces and couln't put it back together!
  • Canon Master
  • 4,338 Answers
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 13, 2008
Repeat E3 paper jam error with no paper, will not reset
Hello thanks for using fixya
E3 error is mostly because of paper jam
. their may be small bit paper jam in side.
Something inside of the printer makes paper sensor & its not function properly
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The alarm light comes on and then the E3 error
Hi the E3 code is a Paper jam
Have a look there maybe a small bit paper inside
All best: pineworks
Jan 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp 145
check if there is any paper stuck inside..E3 is for paper jam...
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA MP150 Error E3
Hi! Have you checked the correct source for paper feed? you can use either sheet fed paper tray at base of printer and from top loose sheet feed. Make sure selection is correct, button below/to right of pwere switch.
Hope this sorts it, it did this on mine.
Paul 'W'
Onyer~EDson(:0)~[><
Dec 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp145 error 3
it means that there is something still trapped inside. a piece of paper maybe or anything. are you sure you already remove the whole piece of the paper or not?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
E3 error
if u have had a paper jam previously u may have damaged the paper sensor when u removed the paper
Jan 24, 2008 | Canon PIXMA MP150 All-In-One InkJet...
842 people viewed this question
old marine
old marine
