Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Television won't turn on at all
I have a Samsung HLR5656W DLP HDTV it just won't turn, I checked the fuse and it's good. Nothing looks burnt or loose,any ideas will be greatly appreciated.
  • Brad Barnett Nov 15, 2006
    Thank you so much for your expert help it was very much appreciated!
  • vicntiff Jan 16, 2009
    i have a hlr5656w just shut down i replaced lamp and ballast & no luck is there any codes or anything else i can do?
    President:
  • 3,130 Answers
Sounds like a power supply problem. If you know how to test solid state componets and make voltage measurements. Get a schematic and conferm the power supply is bad and go to this link for your samaung parts.http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=HLR5656W&modelid=379072 Good Luck Please dont forget to rate this post.
Posted on Nov 15, 2006
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and value..you can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Why is there white dots appearing on my expensive 61 inch samsung. First it was 2 dots 5 days ago now there are 5 spots and counting.
It sounds like the mirror array is playing up. Maybe caused, as it is mechanical, by dust.
If it is still under warranty, I would have it looked at, if not request a Samsung Authorised DLP Technician takes a look for you. If you are in Europe Samsung may look at it with a view to helping when it comes to repair cost.
Good luck
Dec 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 1080i 50" dlp turn
The problem might be from the lamp. also, there might be a burnt capacitor on either the power panel or the main panel.
First you need to check the lamp by unplugging the television for about 3 hours then unscrewing it open then assessing the lamp to see if it is burnt, if it is burnt, then you need to replace it with a new one, but if it does not look burnt, then you need to understand that there is a burnt capacitor on either the main panel or the power panel.
To check and replace a bad capacitor, all you have to do is to take a close look at the capacitors on the main panel and power panel, if you see anyone looking swollen, burnt or pressed, then it means it is bad and to replace it, you will have to turn the board to the other side and melt off the tips using a soldering iron, then fixing in a new one and resoldering it back on the panel.
After doing that, your television should be in good condition once again.
Take care and good luck
Oct 30, 2010 | Televison & Video
DLP HL-R4667W Resolution 1080
notice it states 'hdtv ready', not 'hdtv'! probably need a converter or upgrade module to get 1080p! read the 'gotchas' in the owners manual!
Good Luck!
Oct 08, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
It started out with 2 burnt pixels and then more and more were burning out. Now after 2 weeks I have about 1000 burnt on my samsung DLP HL-S6186W. Is there anything I can do?
Burned pixels or stuck pixels? Check out this website http://www.jscreenfix.com/basic.php it will help you, but if you got too many I wou;d be looking at a warrentee issuue,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | Samsung HL-S5086W 50" HDTV
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
if you can look on the boards at capacitors ( do a Google of "blown capacitors" ) and then you will be able to see if there are any blown one's on the boards inside, if so some soldering will be needed to replacce the blown one if you can then the issue should go away. if you can not do this a service center can help complete the repair.
May 27, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung DLP HLS5086W - spider crack
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
126 people viewed this question
Jerry Greenberg
Jerry Greenberg
