Question about Acer Aspire 5315 Notebook
Security camera hook up
Looking at a surveillance camera it has three rca plug ins how can i hook this up to my computer i have an acer 5315-2153
There are several types of hook-up that will allow you to use your surveillance camera with your pc. If you have Windows XP or Windows 2000 you can use Belkins Video Bus II which will allow you to plug your RCA Jacks into it's RCA jacks then plug Belkins USB connection into your computer depending on your software that comes with your camera equipment will depend on the quality of sound you will get. The Belkin Video Bus II comes with a cd with the drivers required. This device ( Belkin's Video Bus II ) will not work with Windows Vista!!! There are probably several other devices that will allow you to do a hook up but, the price will vary between 40.00 for Belkin to well over 150.00 for others. Check with Circuit City / Best Buy / Compusa. etc....
Jim0001
Posted on Nov 13, 2008
How do I hook my night owl camera's to my RCA DTv/DVR model DTA880?????
in this case you may need converter
BNC -to - RCA
or HDMI -to -RCA
Feb 09, 2016 | RCA Home Security
How do I set my lcd monitor m170cp2 to turn on my security camera
power to camera,wire from camera,plugged into right spot?
Jun 23, 2015 | Vision Home Security
My Viper remote start for a manual transmisson when initiated will start the car but the cardoesnt stay running.It attempts this three times before not trying anymore.I hadit looked at by the installers...
Sounds like they hooked it up as voltage sensing and not tach sending. I'd get them to hook it up to a tach source, as your charging system might be too weak in the cold to give the system a voltage it is looking for.
Mar 02, 2015 | Viper Security and Remote Start System...
I have a camera its a Astak night vision color camera how can i hook it up to my TV its a sony
providing model #s in your question would be useful. Depends on the output of the camera, it has to match your TV or computer. If the camera has a RCA output and you TV has a RCA input, plug it in and your fine. If the camera has a Ethernet or wi-fi output, it has to go to your router then to your computer. If you can port internet to your TV, then you can get the camea also on the TV.
May 02, 2014 | Home Security
6 PIN DIN to RCA Converter Cable with power for security camera
WHOA we'll kinda hard when there are 50 different camera co out there need the camera co name and camera model
Jan 27, 2014 | Home Security
Need driver for surveillance system
Hi, I wanted to share this article on the uses of mini surveillance cameras and how they can keep your home safe. It's pretty interesting how some of the mini cameras can be made to look like everyday items. Some times we need to record a video or wants to take a beautiful photo of something in a very short time, try this site its very useful, clik this http://www.ankaka.com/Wholesale-spy-cameras_c10086?
Apr 10, 2013 | Home Security
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
Hi Boybest,
Yes it's possible.
You have several options with your TV. You can use the Video-In from the auxiliary/line in or even though a VCR. The plugs in this case use what are called RCA Jacks. They travel in three's, one yellow, one red and one white. The yellow is the Video.
Any hook up is going to be dependent upon the output from your camera. Security cameras, for the most part output a video signal much the same as a VCR. Some however use RF (Radio Frequency) which requires it to be attached to a cable or antennae jack and then tuned in (usually channel 3 or 4).
If it's a straight NTSC Video signal there should be no problem. A long cord with RCA jacks to the Video-In would do it. Then you could switch the channel to AUX or Line One (which ever your model uses) to get the camera signal.
Computer cameras have a whole different way of doing things. If you run into any snags, comment me back with the make and model of your camera. I'll get you up and running.
BTW, good things come to those who rate. ;-)
Hope this helps.
Mike
Feb 12, 2009 | RCA 20F420T 20" TV
Acer Aspire 5315 Notebook Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
