Question about Hoover Washing Machines
A hinge on my washer has broken, bought a replacement but cant get a screw out not sure if it is an alan key or not?
  • 135 Answers
These are star key screws. A local diy shop should stock a cheap set. once removed lift hinge to remove.
Posted on Nov 13, 2008
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
Water leaking from machine,trying to lift top of washer looks like hinges in back but cant seem to open
usualy there are hinges in the back and spring clips in the front, lift the front top usiing a bit of force( pry it with a thin piece of wood). make sure all the screws are off around the top , and pull out the lint fillter , there may be 2 more screws there
Jun 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore oasis toploader he l hinge and switch removal
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 24902 Top Load Washer
Broken hinge in hp compaq nx6110
Two things you will have to do.
First, remove the bezel that is between the F keys on the keyboard and the monitor. There may be a couple of little screws from the back to allow you to remove the hinge cover. Once this is out, you see that there are 2 screws on each hinge that will have to be removed. After you have had all that fun, you will have to take the monitor apart by removing the screw covers that are between the glass and the edge of the monitor, then you will be able to separate the bezel, which is around the glass, from the back cover of the monitor. Walla, the hinge supports will all of a sudden appear, and you can remove them. Re-assemble in just the reverse.
Don't misplace any of the screws, and have a lot of fun.
Good luck, and feel free to rate this response.
Mar 15, 2009 | HP Compaq nx6110 Notebook
How to replace hinge lid pins
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
