Question about HP Pentium III , 1000 MHz Processor
Random Shutdown Why does my laptop shutdown whenever i use MS Word? The battery is fullt charged but whenever i try to open a document saved in MS Word and edit it, my laptop just shuts down.
    Problem Solver:
  • 4 Answers
Have you checked for viruses - specifically macro viruses in Word? Can you open your document using another/alternative editor? Does it happen in a specific doc or just a particular doc/s? Another way you can check assuming you can still open Word - try bringing up the MS Visual Basic interface (alt-F11) when you open Word. Check if there are any modules/macros active - don't forget to also check on the normal.dot template (known to be infected by some viruses historically). Another way to go is to completely uninstall and re-install Word. This assumes that your program is bad and not the doc.
Posted on Nov 30, 2006
I have a problem with my pc when I shutdown it down. it comes with force shutdown. it never had m before. how can I fix this problem. if it is a problem
This usually means that there is a program open that is unable to close itself properly, or maybe you have a document that has not been saved, so there is a dialog box asking if you want to save it, but you cannot see if it since you are on the shutdown screen. When it asks if you want to force shutdown, you should see a list of which programs are still shutting down, check on those.
Sep 07, 2017 | Computers & Internet
Random shut down
Clean the cooling sistem and change the thermal paste
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Compaq presario cq57: Random shutdown after 5-10 minutes whenever not plugged into the ac adapter. after the first initial shutdown the laptop, when turned back on, will not stay on for more than 1.3...
try using a can of Air Duster on the bottom of CP57 where your fan is located to clean out the heatsink allowing your system to stay on and figure out the issue.
Sep 22, 2013 | HP Presario Computers & Internet
Toshiba satellite pro does not fully shutdown
In Control Panel, select Power Options, you didn't post your OS?, set to High Performance, open Change Plan settings, set Computer Sleep Never, open Change Advanced power settings, scroll through the settings, set Sleep and Hibernate to Never, open Power Buttons and Lid, set to shut down. Now the red X on the Battery Icon usually means the battery needs replacing, it's not charging. Shut down the Laptop unplug, remove battery, plug in , reboot.
May 12, 2013 | Toshiba Satellite Computers & Internet
The remote procedure call failed and did not execute
Tried pressing the start-up button for about 3 to 5 seconds? That should normally force the laptop to shut down. If not, taking out the battery will surely do the trick.
Mar 28, 2013 | Computers & Internet
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
    If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
    But, if the Computer shuts down randomly, it is due to the Processor.
    All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
    The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
    As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
    Replacing the Cooling Fan in the Computer should resolve the issue.
    Jul 05, 2010 | Computers & Internet
    Not charging when it says charging
    I was going to suggest a recalibrate might do this
    with some machines run the battery to flat then fully charge at full charge shutdown and reboot windows.
    With some machines the same thing is done as follows:
    Enter the bios and disable the automatic shutdown for low battery. Disable the automatic shutdown for low battery in Windows. Run the laptop until it just dies from the battery going dead.
    Charge the battery. Re-enable the automatic shutdowns.
    And I believe some even have options in the Bios to recalibrate.
    If this doesnt work then could be a voltage issue in the charger (is it universal with voltage settings?)
    if it is this and no settings that could have been moved to wrong voltage etc, then maybe need testing and replacing.
    Hope this helps
    Jun 10, 2009 | Dell Inspiron 6400 Notebook
    My laptop have a light that it is charging but couldnt open.
    PUT OUT THE BATTERY OF LAPTOP AND REINSART IT THEN START THE LAPTOP OK
    Apr 23, 2009 | HP Computers & Internet
    Random shutdown and hard reset
    I had a similar problem and it turned out that there was a backup program called ´Sprite´ that was loading an image file of the system after every hour of use, erasing all changes to the configuration and saved data.
    The folder of the ´Sprite´ program has a text file with the configuration data. I opened the text file and set autoexec. and similar options to ´false´ and saved the file again. After that, the problem had disappeared.
    Regards,
    Joep
    Jul 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
    HP Pentium III , 1000 MHz Processor Logo
    329 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
