Question about Car Audio & Video
Wen i desconnect the key from the ignition the radio ressets all that i programed in
    Problem Solver:
  • 6 Answers
Make and model of the car?It's rather simple.Many German and French cars have the permanent and the accessories power cables switched.Switch them back from the stereo's connector's cables.(The red to yellow and the yellow to red).First it would be a good idea to check that out with a voltmeter.
Posted on Nov 14, 2008
Wen i have door open and key in the ignition playing the radio.i wont to no how can i disconnect the dinging bell altogether. 2002 chevy trailblazer.
If you have a factory radio, you might be able to threw the radio. Get to the menu and personalization part. If not, you can remove the key in switch on top of the lockset, in the steering column. Small white switch on top.
Sep 11, 2016 | 2002 Chevrolet TrailBlazer
How do i disconect the dinging wen the key is n the ignition. Its anoying wen radio is playing 2002 chevy trailblazier
You can't disconnect the chime, it goes thru the radio and is generated by the Body Control Module (BCM).
Can you program a pats key when you don't have a good key and only had one key?
Mate I'm in Australia and I own a 2nd hand 2001 holden commodore which I had only 1 worn key, I went to a holden dealer with my registration and licence(to prove I owned the car). For a small fee they printed out my
BCM security number(to program my key fob
Car key number-Ignition(to cut key)
Radio security pin number and Radio serial number and I still have the print out in case I ever need it.... MAYBE YOU CAN DO THE SAME WHERE YOU ARE.....
Mar 21, 2016 | Cars & Trucks
Lost my remote on my 02 jeep liberty and need to
the key fob? or radio remove or what?
remote to what.
the operators manual covers this , under car keys.
the car came with 2 Fobs. lost them both now>?
RKE its called, (makes looking fact more easy)
is this car with SKIS Immoblizer option> yes./no
if yes.
SENTRY KEY IMMOBILIZER SYSTEM - IF
EQUIPPED
im reading your operators guide now.
lost that too>?
Duplication of keys may
be performed at an authorized dealer (or locksmiths) or by using the
Customer Key Programming procedure.
DIY, takes 1 key , good, called a valid key, in the below text.
You can program new keys to the system if you have two
valid keys by doing the following:
1. Cut the additional Sentry Key Transponder blank(s) to
match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch and
turn the ignition switch ON for at least 3 seconds but no
longer than 15 seconds. Turn the ignition switch OFF and
remove the first key.
3. Insert the second valid key and turn the ignition
switch ON within 15 seconds. After ten seconds, a chime
will sound and the SKIS indicator light will begin to
flash. Turn the ignition switch OFF and remove the
second key.
4. Insert a blank Sentry Key into the ignition switch and
turn the ignition switch ON within 60 seconds. After 10
seconds, a single chime will sound. The SKIS indicator
light will stop flashing, turn on for 3 seconds; then turn
off.
The new Sentry Key has been programmed. Repeat this
process to program up to a total of 8 keys.
did i guess right, the Key FOB RKE,
remove key entry fob.?
Sep 18, 2014 | 2002 Jeep Liberty
Programming a honda transponder key
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
  1. Turn the ignition on
  2. Press Lock/Unlock within 4 seconds
  3. Turn ignition off and hen back on within 8 seconds
  4. Repeat steps 2-3 two times
  5. Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
  6. In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
  7. Switch ignition off and then remove the key
Civic 1996-1998
  1. Turn ignition on
  2. Press and hold the valet button which is situated on the radio within 5 seconds.
  3. System should now lock and unlock the vehicle indicating it is in the programming mode
  4. Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
  5. Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
  6. Release valet key
Radio remotes 2 and 3 button types
  1. Switch ignition on and repeat for 3 times.
  2. Press he lock button, switch the ignition off and back on and then press lock button again.
  3. System should now lock or unlock
  4. Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
  5. Switch ignition off to exit the programming mode.
If you will have any further doubts or question to ask i suggest you to check out the page where i found this which is http://www.carkeyadvice.com/step-by-step-fob-programming-guides/honda :) i hope this was the solution you were looking for mate! happy happy new year!
Dec 30, 2012 | 2007 Honda Pilot
Resset my oil change dodge caliber 2008
1. Turn key in ignition to "On" without starting the car...
2. Depress accelerator fully 3 times within 10 seconds
3. Turn key in ignition to "LOCK".
on number 2, do it slowly all the way to the floor but within the 10 seconds
Jun 23, 2011 | 2008 Dodge Caliber
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
