Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side cold, frige side warm
I have a GE Profile side by side frige. Model TFH30PRTAWW. Freezer works fine, frige is warm. Damper was closed and would not open as required. I took damper door off to open up hole between freezer and fridge. Still no cold air coming through opening. Is there another solution to get cold air into the fridge side?
  • 4 more comments
  • theheathen Nov 13, 2008
    Actually "yes" to both questions. Fan is working and there is frost forming on the back wall. Thanks for the help.
  • dpete8182 Nov 16, 2008
    My freezer works fine. The defrost is working but the refrigerator stays ta 50 degrees. We've cleaned the coils, etc.
  • 9990000 Nov 24, 2008
    refrig side is warm and the rear wall in the freezer is freezing up
  • Anonymous Nov 24, 2008
    i have the same problem.had refr man here in aug for part .think iam gona get rid of this pos ge and get a kemore.ge parts are way to high.
  • azstars52 Nov 24, 2008
    iam having the same problem with my GE .I had a part put in in august think it was the termostat.now the frige part isnt cool enough the frezzer part is fine.think this GE is is gona cost an arm and leg for parts this Ge is gona nickel and dime me to death.think iam gona get ris of this P O S and call it q done.
  • Anonymous Mar 24, 2014
    were is the vent damper
    Problem Solver:
  • 18 Answers
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
    Genius:
  • 1,122 Answers
First,is the freezer fan working?second,is there frost forming on the back wall of the freezer?let me know more-mike
Posted on Nov 13, 2008
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
I have a ge profile psc23nhpa refriderator that the fridge side of the unit temperature shoot up to 135 over night. But the freezer side was still very cool. What could cause this?
Are you sure it is 135? If the freezer is cold but the fridge is warm, most likely is the damper door problem. (Basically, it's a door controlled by the main board, get cold air from freezer and close when the fridge is cold enough)
Oct 17, 2010 | GE Refrigerators
Freezer working and frige side is warm
Most likely the damper solenoid/motor has failed - or the damper flap itself is frozen/warped so it cannot open and close freely.
The thermostat may also be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | GE Refrigerators
My GE Profile side by side refrigerator is
Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment. Let us know what you find and we can go from there.
May 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I have a GE GSS25LGMF side x side refrigerator. The compressor never shuts off and everything in the fridge section is freezing. Is this a thermostat problem?
it could be the damper part number WR49X10091,if the damper door isn't closing correctly cold air will just keep coming into the fridge side from the freezer,usually the damper door opens to let the cold air in when the fridge starts warming up and when it gets cold enough the door will close but your damper is stuck open
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator interior heating upwards of 90 degrees/freezer seems fine
is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Oct 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
953 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
