Question about Riso RZ220 Duplicator
Machine won't operate.
The drum door was opened before the green light was on and now we can't get the machine to do anything? Can I fix this?
  • 3 Answers
Yes, you need to rotate the drum shaft to the home state and reinstall the drum
best reg.
pini cigler
Posted on Nov 14, 2008
Door won't open
You will need to remove the top cover of the washer and reach down to release the door with the manual release.
Apr 25, 2012 | LG Washing Machines
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
Dec 10, 2011 | Asko W6021 Front Load Washer
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
During the spinning cycle machine makes grunting noise and it doesn't spin. After few minutes of only noise all the lights on the dial are flashing and it doesn't do anything else. The doors are...
Sounds like you have some thing caught in the drum and/or drum bearing has give up the ghost---another thought is the drum brake is being applied while trying to spin--something could be out of sequence with timer and/or wires crossed/shorted causing functions at wrong time---can you spin it when it's off ?? the reason being you can't open the door while running is a safety factor--water doesn't run on floor--somebody getting arm caught in drum etc etc----do you have the operating manual--if so does it have trouble shooting section---to check this out while operating is a very very dangerous situation---this better left to a professional do to the machine being able to mutilate or dismember parts of you.
May 31, 2017 | Kenmore HE2 Plus Front Load Washer
Door is closed and the light stays on. after a while non of the buttons will work any suggestions.
I have the same problem but my interior drum light stays on whether door is open or closed; in either case the control panel becomes in-operable after about five minutes. I unplug the machine for 5 to 20 minutes then plug it back in and it is powered "on" the moment I plug it in (i don't even have to push the power button). Then the light remains on but i am able to operate the control panel so i can do a load of clothes. Then if the machine sits idle for no more than five minutes, the control panel becomes in-operable again and the interior drum light stays on.
Any one have a clue???
Nov 09, 2010 | LG WM2501H Front Load Stacked Washer/...
How should I change the cartridges
What cartridges do you need to change? There are only 2 in this machine. If you open the right side door with the release button then open the front door you can see the 2 cartridges. The one on the left side with the green button on it is the toner/developer cartridge. It is replaced most often. When it needs to be replaced you will see a light on the operation panel that looks like a stack of 6 dots. You just press the green button down and slide the cartridge out.
Just to the right of the toner is the drum cartridge. When it is due for replacement you wil see a light on the panel that looks something like a small flashlight battery or barrel. You can just slide the drum cartridge out, but only after removing the toner cartridge first. The toner cartridge must be out of the machine before removing or installing the drum cartridge.
Good Luck and Thanbk You using Fixya.
Sep 03, 2010 | Sharp AL-1655CS Laser Printer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
118 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
