Question about Samsung RS2630SH Side by Side Refrigerator
Screeching Noise Hi I followed one of your suggestions. It seems its the fan making the noise because when I stall it the noise stops. I even sprayed some WD40 on it and that seemed to temporarily some the problem. What should I do with the fan? Thanks!!!
  • 237 Answers
If you know that the fan is the culprit then it can be replaced. The motors are fairly cheap and easy to replace.
Posted on Nov 18, 2006
I have a Samsung Tab A6 that keeps making a loud screeching noise And boots itself it was freezing the screen but when I factory reset it that seem to stop now it's just making the loud screeching noise...
Where did you get the phone from.?
I suggest you take it back to them & get your money back as a screeching sound is usually a network-lockout noise from a stolen phone.?
Best of luck.
Mar 09, 2018 | Samsung Tablets & eReaders
My question is related to the previous thread. However id like to reitterate the problem so that whoever stumbles upon this thread on google could help them immensely. I bought my mitsubishi montero sport...
Ian,
There are two fans in a vehicle, One is in the engine compartment and is for the radiator. The other is in the passenger compartment and it runs the heater and air conditioner air flow from the plenum. The condenser is near the radiator and the evaporator is in the plenum. Condensers don't fail. Neither do evaporators. If the squeal is coming from the engine compartment when the air conditioner is turned on, the problem is either the belt to the COMPRESSOR or the CLUTCH on the compressor.
Jun 20, 2014 | Cars & Trucks
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Sep 30, 2013 | 2005 Chevrolet Express Cargo
I have got a 2003 Mazda etude 160 ie and recently changed the clutch and pressure plate. There is a noise coming from the engine and whenever i press the clutch (even slightly) the noise stops. Could this...
You posted this question in the "Tripods" area of FixYa. Please repost in a more appropriate area so that the proper experts can see it and give you a solution.
Sep 26, 2012 | Sima B00006jq6c Universal Quick Release...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
U-line 75 WC makes a screeching noise on and off during the day. What can I do to make it stop?
You may have one or two fans on the unit. One normally next to the compressor and one in the evaporator With the unit running listen if the noise is comming from inside or outside. Outside is easy, spray Q20 onto the motor and run untill you are able to buy a new one and replace. If inside, defrost a few hours then remove inside panel and locate the evaporator motor. Spray motor shaft liberally then motor will quieten down. Replace when possible.
Sep 15, 2010 | Refrigerators
2006 Toyota Corolla w/VVT-I 16 valve with 66K miles - screeching sound from engine compartment, belts seem good.
hi, i know you say the belts seem good but one way to rule the fan belt or alternater belt out is to pour water onto the belt and if the noise stops then the chances are the belt needs tightening.
If how ever you still have the noise then this would point towards one of the pulleys bearings running dry you can try putting oil into where the bearing is its difficult to get the oil in their as their is very little gap so using a spray oil would be your best option.
If after doing this you still have the noise then your going to have to replace the pulley thats giving you the noise to find out witch pulley it is spray each one in turn with spray lube and see witch one makes the noise less and then this is the one that needs replacing.
Your power steering pump can give you the noise your getting if the fluid is to low so make sure you check all the levels ok.
Let me know how you get on or if you need further assistance ok
Dec 14, 2009 | 2006 Toyota Corolla
The fan that is behind the bulb is making a loud noise for a few minutes and then the noise stops. We tried spraying the fan with WD40. ?? We can't seem to find a way to remove/replace this fan. Can't...
sometimes dust accumalates on fins of fans and causes rotation to deform and gets fan off balance causing noise .Also heat from lamp causes deformaties on fan and causes fan bearing to make noise.These fans can be replaced fairly easily
Jul 30, 2009 | Akai PT50DL24 Television
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Samsung RS2630SH Side by Side Refrigerator Logo
398 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
