Question about Asko 24 in. 1895 Built-in Dishwasher
Fan in/on dishwasher keeps running - even after cycle is finished
I bought a house that has the 1885/1895 dishwasher. For the past 3 years the washer has run like and charm... still is. But now the fan on the inside of the door (behind a panel in the upper left) will not shut off. I've tried running the whole cycle - still won't shut off. Flipping the breaker - and when the power comes back on - the fan comes right back on. I've tried clearing out the settings - the fan still won't shut off. It has been running none stop for 3 weeks now and makes me crazy. Can you please offer a solution? Thank you.
  • jebep Mar 08, 2008
    I have the same problem with a model 1595. Any new solutions? Is the circuit board repairable....I can solder with the best of 'em!
    Is there a schematic available for download?
    THANKS!
  • 175 Answers
I have seen this problem before and there are only 2 things you can do about it. 1: take the outer panel off the door to gain acess to the wiring and unplug the fan (it will have a slight negative effect on the drying, but not too much) or 2: replace the control board. The part is about $350-$450 (depending on which board it takes) and that doesn't even include the labor if you cant do it yourself. The only place I know of to get parts for these in the U.S. is american appliance 303 777 0993. If the unit is less than 5 years old, the board is still covered under a parts warranty. Look at your serial nuber on the inner edge of the door to determine when it was built. The first two digit are the year it was made ( so an 01 would be 2001 etc) and the second two digits are the week (so 45 would be the 45th week of the year) HOpe this helps!
Posted on Dec 01, 2006
  • Douglas Henry
    Douglas Henry May 15, 2008
    There is now a recall on all asko models ending in the # 5 and the board and wax motor will be replaced by asko at no cost to you. Go to www.askousa.com to find the recall info and set up a service appointment. If you already paid for a board however, they will not reimburse you.
    Sergeant:
  • 351 Answers
You have to replace the pcb and the wax motor on the fan.if the wax motor is burnt it takes the control board with it.the boards are repairable but you can normally buy a reco board but i would advise using a new one.hope this helps.
Posted on Mar 08, 2008
Fan is noisy intermittently well after wash is finished
It depends on what model you have. The fan is usually operating when the dry cycle is on. The dry cycle can be quite long compared to the actual wash (which ends when the rinse water is drained out). The dry cycle uses the steam in the dishwasher to circulate around the dishes. The fan keeps running until the full cycle is complete. If you are hearing heavy noises when the fan is running, then the bearing of the fan maybe damaged and you need to replace the fan.
Jan 02, 2014 | Fisher and Paykel Dishwashers
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
Electrolux ESI 6180
I was shown how to clear your dishwasher and keep it running much longer. however, be careful when doing this. start with an empty dishwasher. pour 12 cups of cold water to the bottom area of tub and wearing latex, or rubber gloves, measre and por in exackly 2 cups of ammonia. let that solution sit there either all day, or overnight, at least a few hours, then run it through your machine, do not add anything else. do not do this with small children around. if you prefer buy the largest jug od vinegar (white) and pour it full strength into tub of your macine. let stand sevral hours, then put through a light or regulsr cycle. if you encountet that same problem empty, press drain cycle. retry usingrinse cycle instead. let me know if his resolnves your problem.
Nov 15, 2013 | Electrolux Dishwashers
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
My Meile G2243 SCU that had been running fine for a year has started leaving black residue particles sticking to the drinking glasses on top shelf. Have used dishmatic cleaner a few times but problem...
some have used vinegar and water and others have used bleach and water and run the unit on its hotest cycle the black residue is do to a soap build up mixed with the type of water that you have myself I used to do the vinegar or bleach method but have found a product sold at home depots around the world called AFFRESH basicly you just add a tablet and turn the unit on its hotest setting and i know what your probably saying no tablet can clean it all but it does for heavier build up in customers houses I have ran two cycles with this product one after the other and then they use the product once every three months after wards and it keeps this from ever happening again they make this product for dishwashers and frontload washers heck i have even used it to disinfect a fish smelled dishwasher mind you the fish was dead well over a week ex tenant thing in a customers house give it a try I havent met anyone yet that hasnt sworn by this product in the past 3 years that i have been using it. if your not able to obtain this product once again a strong vinegar and water or bleach and water solution will work if you have any further questions message me back and please rememeber to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Jan 25, 2011 | Miele Dishwashers
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Soap dispensor will not click shut
Your dishwasher, although a Kenmore, was made by GE. Dispensers have been a big issue for them in the past; they actually redesigned them quite a bit 3 to 4 years ago. Is it the kind that slides across to lock in place, or does it fold over like a clamshell? Often there is a little spring that holds the lip in place, and it can easily wear out, allowing dispenser to pop open easily. I would check http://www.searspartsdirect.com for technical information, or possibly go to the http://geappliances.com website to see if they can give more information.
May 20, 2009 | Dishwashers
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
Dishwashers Logo
403 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Marvin
Marvin
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
