Question about Pioneer Audio Players & Recorders
DV 868 AVI when disk is placed in machine and you press play ,it does not turn and the screen defaults to 0:0:000,and nothing else happens
Fixed it
Posted on Nov 14, 2008
I have a reading of 0,000. that's not good. how do I reset?
What's wrong with it?
If you want to change the number of digits shown after the radix mark, press f followed by the number.
If you want to change the radix mark between the European and US formats, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
If you want to see a number other than zero, type it in.
Jan 12, 2012 | HP 12c Calculator
Hi, My ps3 used to play avi files and now whichever one i use it ownt play( eve if it played it previously) its pauses and a small clock appears in the bottom left hand side of the screen. I dont...
1) Reset the settings on the PlayStation 3 by having the unit turned off, then pressing and holding the power button on the front of the unit until you hear it beep twice (shouldn't take more than 7-10 seconds), then release. All of your settings will be reset to the factory defaults, and you can make adjustments as needed.
2) if you are streaming the avi files from a media center via wifi it is more than likely a connection error try hooking up your ps3 directly with an ethernet cable to your router if possible this should fix the problem
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Nov 25, 2010 | Acer Aspire One PC Notebook
Have the Samsung BDP1590. The screen only says CLOSE and will not do anything else. Tried the reset instructions but nothing happens. The DVD player is less then a year old. Can someone help me out.
I had this problem when trying to play Avatar and my player locked up. I'll assume you have a disk inside when this happens.
Try pressing the power button to turn it off, then turn it back on again but as it starts press the Open/Close button - you may have to do it twice because at the first press my BDP1500 says "CLOSE" then a second quick press will show "OPEN". Take the disk out, then try another disk. If it's a problem with trying to play a recent disk you should be ok until you try to play it again. Read up on updating your firmware, etc. Good luck.
Sep 18, 2010 | Samsung BD-P1500 Blu-Ray Player
Full Desktop does not appear, video does not show.
You must tell the laptop to change display mode--there are 3...Normally, the key-press is something like "function key, F4"--look for a small tv screen symbol on one of the "F" keys--default mode is "laptop only", Press and hold "fn" and then press the appropriate "F" key, the laptop will switch to "laptop/external display". Another set of key presses will get "external display only" mode. And, finally, the next sequence will bring you back to the default mode. Make sure you turn on the computer and *then* turn on the projector to head off any sync probs.---Rick
Sep 21, 2009 | CTX Optoma EzPro 710 Multimedia Projector
Auto Initilizing of disk unwanted
my apoligies... it was that some disks hadnt been finalized, it just so happened that the the three I stuck in the player hadn't been finalized. Big coincidence that i chose those particular three. But its all good now.. the other player plays them... stoked.
Jan 06, 2009 | Sharp DV-NC80 DVD Player/VCR
Avi file
Please down load and install the latest version of media player for your version of windows. or you can download and install winamp with its video plugin which will play .AVI file easily. Also make sure that you have installed correct display driver for your hardware. Normally no video codec is required to play original .AVI file. I think you may have a DV video fire (.AVI) file. This will play if install the DV video codec. Media player classic will play most of the formats.
Oct 01, 2007 | Ahead Software Nero 6.0 (60045) for PC
Dvd Jammed
There should be a tiny hole that you can get a paper clip through on your DVD this hole leads to a manual release mechanism that should open the DVD drawer. I hope this helps
Sep 10, 2007 | Shinco SDP-1250 Portable DVD Player with...
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Cannot watch anything
Just head cleaning cassette and play ones
Feb 10, 2007 | Sony Handycam DCR-TRV33 Mini DV Digital...
82 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
