Question about Sony Walkman WM-FX290 Personal Cassette Player
Flashing letter E on screen what does this mean
Walkman will not play wirh E flashinf
Transfer music from my HP Laptop to my Walkman some songs on my Walkman will not play instead CANNOT PLAY LICENSE NOT VALID will come on screen, music is from my CD collection put on my laptop
The message means the music is copy protected and that means it will not play outside the device it was downloaded to, in your case the Walkman.
Feb 16, 2017 | HP Audio Players & Recorders
It turns on and shows a screen that I have never seen but does not flash or charge. It started to skip every other oict when flashinf fast. Then it died.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your flash is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Nikon Speedlight SB-800 TTL Flash
Dont know the model no of my old Sony walkman
Sony is rather peculiar when it comes to naming their player, only using model numbers that require a degree in cryptology to make sense of. It does make some sense but may not be obvious at first, especially for people not familiar with Sony’s. Therefore, here is a short guide:
The First part of the model number is either NW or NWZ. NW is Asian models, NWZ are American and European models. NW = Network: Walkman
The second part is a letter and 3 numbers. The letter shows the model type and the first number shows how advanced the model is, more or less.
The second number shows the generation. The first generation was players such as the A800 which used sonic stage. Then the A810 came as gen 2, A820 as gen 3, and we're now at gen 4 even though there’s not A830 (yet) - there are however other gen 4 players.
The last number shows capacity. 3 means 1GB, 5 means 2GB, 6 means 4GB, 8 means 8GB and 9 means 16GB. 0 is an indication of the player regardless of capacity.
Sometimes the model number is also shown with one or more letters at the end. Often that’s the color, ex BLK for black. KB for the A820 series means Bluetooth, headphones are included.
Most the players follow this rule more or less but of course there are some exceptions when it comes to Sony.
Series:
B - Basic - stick players
E - Economy - small flash players, current model E430
S - Specialized - medium flash players, current model S630 and S730 (extra feature for S730: Noise Cancellation)
A - Advanced - large (screen) flash players, current model A720 and A820 (extra feature for A820: Bluetooth)
Example of use of these model number codes:
The NWZ-A829 vs. the NWZ-A726: Both are European models. Both are the A series, generation 3, design is identical. The A820 has BT which the A720 doesn’t, hence the higher numbering for more advanced features. The A829's last number, 9, means its 16GB. The A726's last number, 6, means it’s 4GB.
-A players getting noise cancelling NW-A820, but then NWZ-A820 does not get it.
-S players have radio added on while A does not. Again one could argue a radio is specialized and so its on the S model
-although it is possible headphones also play a role, the new E43x models come with cheapo headphones while the S63x models come with higher end headphones and the 700 series usually coming with noise cancelling headphones and always with the S letter (this started in the first gen 700 series with the Noise cancelling)
HD based player naming scheme
They initially started out as flash based but moved to HDD in the HD-1 (hard drive 1) then moved onto HD-3 and then HD-5. Of course the numbers only showed that 5 was newer than 3 and so forth. Then the newer HDD based models arrived, the A1000 and A3000, and later the A1200. Unfortunately the numbers didn't show well the sizes of the hard drives
A1000 - 6 gigs
A1200 - 8 gigs
A3000 - 20 gigs
although divide 6/1000 = 0.006
0.006x1200 = 7.2
0.006x3000 = 18
so its not close to the 8 and 20 gigs
Atrac vs Non-Atrac
Although I agree NW and NWZ specify which area the device is sold but it wouldn't be Asian vs. NA/Europe since the NWZ models are on sale in India, Australia, New Zealand, and other Asian countries. It probably is to differentiate between atrac and non atrac models. Since all NWZ models can't play back atrac.
Generations and Capacity
The middle number, it does show generation
80x - first gen
81x - second gen
82x - third gen
83x - fourth gen (presumed)
But there is no 83x but there is a 73x series and 63x series on sale now, so and this signals the 4th gen
Ex. F in the naming signifies radio (FM) as in NWZE436FB, FM radio and black in color.
As for capacity, since 9 is 16 gigs now is it highly possible that 9 will become 32, 8 will become 16, 6 will be 8 gigs, but I have no such info to support this idea.
Colors
R - Red
B/BLK - Black
S - Silver
P - Pink
L - Blue
I am sure more could be added but I'd have to dig for full model numbers of older players.
Sep 28, 2009 | Sony Walkman NWZ-S616F MP3 Player
The screen just keeps flashing on and off all the time
I have a sony ericson walkman w810i and the screen keeps flashing on and off. I have tried removing the battery over night but this hasn't helped.
Jul 05, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
May 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
Protected card flashes on my screen and I can't take a picture
Take out SD memory card. Move switch to opposite position (unlock). Try in camera.
Mar 17, 2009 | Fuji FinePix S2000hd Digital Camera
Flashinf H F
check your fill hoses,,for kinks,,or clogged,,the unit is detecting no water ate one or booth of the fill hoses..clean your screens,,,onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Sony Walkman WM-FX290 Personal Cassette Player Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
