Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Replacement of keyboard on a hp ze 5000 laptop
I need instructions on replacing the keyboard on a hp ze5000 laptop.
Does the keyboard come out from the top or do I need to remove all the screws from the bottom of the case ??
thanks jeff
I got it fixed, There are 2 small screws on the back of the two hinges that fold the display monitor open and closed.
Remove the two screws ,and then with a small screwdriver gentley pry up the hinges. Then pry up the metal grill that sits at the top of the keyboard, (the hinges are part of the metal grill) it has clips that will pry up with the grill.
Remove the 4 screws at the top of the keyboard, this will allow the keyboard to lift up and slide it off the bottom tabs.
Pry up the white clip that hold the ribbon connection and the ribbon will pull right out.
Put the ribbon back in and push down the white clip to secure it.
Replace the 4 screws and reassembly the grill
Posted on Nov 13, 2008
    Scholar:
  • 69 Answers
My buddy and i put together a video a while ago for this you can find it here
This is not your model but the concept is the same.
Disclaimer: careful bad things can happen, not responsible etc etc :)
good luck and tell me how it goes, please don't forget to rate.
Have a HP ...the keyboard is frozen,will not let you type. Cat layed on th keyboard. Help!!!
Check to make sure all the buttons are bouncy and not stuck down. If all the buttons seem OK then it may be broken and you will need to replace it. Try a USB keyboard to make sure the laptop is still working correctly.
Mar 04, 2011 | SIB Laptop US Keyboard for HP Pavilion...
My mouse and keyboard freeze up momentarily EXACTLY every three seconds. Re-installing the OS twice didn't help. Wiped HD and installed again still didn't help. Computer is an HP ze5000 laptop.
need more input to isolate the problem... does this occur when on power... does this occur when not on power... if ur system is old then is there lint settled within ur fan vents... all remaining the same seeing such a precise count i would suggest get the mobo cleaned up and checked for dust and i would conclude that u either need a BIOS update a BIOS reset or a hardware assistance... hardware assistance in any form for laptop would be to replace the MOBO costly!
Aug 26, 2010 | HP Pavilion ze5000 30 GB Hard Drive
Need f key instructions to reset hp pavilion ZE
No key needed, just boot from the recovery cd that came with the laptop when you bought it and follow the instructions on the screen.
Oct 28, 2009 | HP Computers & Internet
Power Supply Port Burnout
1) You need to replace the DC Power Jack. This is the port on the laptop where the AC adapter (Charger) plugs in. {Power port}
Most so called repair shops won't touch this. (Notice I stated so called) They will want to replace the entire motherboard. {Geeks are us}
A bona fide computer repair tech can replace the DC Power Jack. Cost of jack? Around $10. Repair bill? From $50 to $125.
[Entire laptop needs to be disassembled, down to the bare motherboard in the tech's hand. Precise de-soldering, and soldering skills, are needed for the DC Power Jack replacement. Reassemble laptop.
This gives you an idea of what is involved,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6500-dv6600-dv6700-dv6800-notebooks/
[Older HP Pavilion DV6500 through DV6800 models]
DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
2) Replace the AC adapter. If the AC adapter has a separate cable from the power unit, to the laptop, then by all means just replace it. May be more of a headache, then just buying a universal AC adapter.
Barring none of the above is a feasible approach for you, and you wish to save the information on the harddrive, of both your laptop, and your brother's, I would suggest an economical external enclosure.
Remove the harddrive, and install it in the external enclosure. The enclosure has a USB cable, and is plugged into any available USB port on a separate computer.
(Desktop?)
The HP Pavilion ZE5000 series of laptops, (Business Notebook's), use an IDE (PATA) harddrive.
It is 2.5 inches across in width.
(Desktop harddrives are 3 and 1/2 inches across in width)
This is one example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3169580&CatId=2782
To remove the harddrive, I'll need to know the exact Product Number.
(P/N)
This is on the bottom of the laptop in a white Service Tag.
(DO NOT give out the Serial Number. S/N)
Feb 10, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
How do I open the HP Pavilion ze 4300 to replace the powerjack
All screws need to be removed off the back of the computer then you need to flip the computer over and then remove the plate right above the keyboard and remove the screws there. Once that is done you will be able to get into the motherboard
Feb 08, 2009 | HP Pavilion ze4300 Notebook
Noisy fan on a Compaq laptop Presario 2500.
Have you tried following the instruction in the Service Manual(pdf) published by HP online?
Nov 30, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
I NEED TO CHANGE THE KEYBOARD FOR MY LAPTOP BUT I NEED THE ONE FOR SOUTHAMERICA
sure..www.hp.com has an accessories area for that..HP owns compaq now.
thankya for using fixya
May 27, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Hard disk hp pavillon ze 5400
Google is your friend. Or better yet: www.froogle.com (shopping.google.com).
Find out the model number of the hard disk then search for it.
Apr 09, 2008 | HP Pavilion ze5000 30 GB Hard Drive
Presario 2500 hp
just google Compaq Presario NX9010 replacement DC Jack
Jan 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
167 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
