Oct 23, 2009- This is how it went for me..I have a
Samsung SYNCMASTER
2053BW. I leave my monitor on and let it
hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on
Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A
SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from
phone.
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too.
Oct 23, 2009- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top
notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
I recently bought a Samsung 953bw Syncmaster LCD monitor and have troubles with the display. When I leave it running for awhile (either by doing nothing or playing a game), it shuts down as if going to sleep. But when I click/move the mouse or press the spacebar, nothing happens. The only time the display comes back is when I turn the monitor off for a few mins and then turn it back on. Has anyone else run into the same problem? If so, how did you solve it?
Thanks
mine started like that - on and off display but now it's giving me just a flashing blue light and nothing more.
anybody has an idea what's wrong with this unit?
thanks.
same for me.been through "troubleshooting"in the manual still nothing but a flashing blue light.
My 953bw has the same problem. After 8 months, suddenly no display, blank screen, just the power light blinking on and off. Troubleshooting guide did not help. Anybody know what to do before sending it in for repairs?
