Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Color problem after new lamp
I put a new lamp in my pt50lc14 the left side has a diffrent color than the right
  • 37 Answers
Get a new bulb, you shouldn't be having a problem like that with a new bulb
Posted on Mar 12, 2009
RIGHT SDE TURN SIGNALS NOT WORKING 2005 VOLKSWAGEV TOUREG
fuses first
remove all right side lamps X2 (some outside usa have 4 )
now put in , just 1 new lamp. does it work?
the this 1 new lamp in all locations Right.
yes, then one of the others was shorted. or all 2 or 4 were bad.
no, then check right side wiring (1 blink wire color for shorts or opens)
if the wires are good the combo switch is bad or it s connector.
using a voltmeter makes it far more easier.
12v good (at blink moment) 0v bad, 6v shorted.
see?
Oct 12, 2013 | Volkswagen Touareg Cars & Trucks
07 Chevy Cobalt brake lights do not work. turn signals work, tail lights work, Cyclops brake light also works. Fuse is good. New bulbs
so 3 lamps (usa deal with cyclops)
and you say 2 fail L/R and center works?
is that true. or a typo.... ?
if never seen any car wiring go to center then left then right
in a daisy chain.
most go left , then both seperate path to center and right.
in USA, we have LHD cars, not right. side. drive.
and RHD cars are wired, backwards.
i refuse to do world wide Cobalt market look ups. no country state and all lights is different world wide as are color codes.
ok try on light at a time, put in, take out,move it 3 times.
works?
I bet all 3 are dead for brakes.
if true.
its the brake lamp switch malfing.
or cut wires ,due to trailer hitch goons. (hackers)
Oct 09, 2013 | Cars & Trucks
Need to reset lamp hr. meter on panasonic pt50LC14 tv with out the remote
Unfortunately you might need the remote. Otherwise up is channel up down is channel down left is volume - and right is volume +. Enter is the input/source button. A new original remote can be purchased here http://www.replacementremotes.com/Panasonic/Buy-EUR7603ZB0-Remote-Control.html
Feb 08, 2011 | Panasonic PT-50LC13 50" Rear Projection...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Flashing "LAMP" bottom right side
Unplug the set from the wall. Next you will need to remove the Lamp Door on the right side of the set. Just one screw and you can remove the door. Next you will see the lamp inside. It has two gold colored screws. Loosen both screws and grab the handle and lightly wiggle side to side while pulling the lamp out. Warning!!! DO NOT TOUCH THE FRONT GLASS AT ALL on the old lamp and the new lamp. If you see shattered glass inside the lamp then you have a bad lamp. There will be a Lamp Code sticker on the left side of the set. Record the lamp Code and purchase a lamp. Once you have the correct lamp just reverse the process. Make sure you have the Lamp Door on correctly and the screw in or else the set will not come on.
Jul 12, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Rewiring taillights for a 1990 corsica
The color coded wires are alike for both side with the exception of the directional lamp. The color will be the same although a different colored stripe will be on it.
May 27, 2009 | 1990 Chevrolet Corsica
TY-LA1000 LAMP UNIT
the lamp is located in the front. take off the front cover (it's a snap-on) then use a phillips head screwdriver to take out the lamp. the lamp will be located on the left side.
Mar 01, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
