Cassette tape spills when stopped in 'play' or 'fast forward'.
Akai GX-95 MkII Stereo Cassette Deck: Tape spills from the cassette when it is stopped while in Play or Fast Forward mode. Brake is not operating correctly. In Rewind mode there is no tape spill. Can you give guidance on adjusting the brakes? I am competent to do the work if I know the correct procedure. Alternatively , if a service manual is available for purchase that would be great.
Is it possible to obtain replacement brake-pads if they are needed?
Thank you, Eric Fahy
  • ej_fahy Nov 14, 2008
    Thank you for the solution. Can I presume that the offered Gx-F95 Cassette Service Manual applies to my GX-95 MII Cassette Deck? If it does I would like to purchase a copy, please.
    President:
  • 1,952 Answers
The spooling assembly is fixed to thespool motor axis by means of a retaining ring with six radial reedswhich extend and grip the axis when the assembly is screwed to theaxis. Apparently, this steel-to-steel mount doesn't hold anymorecausing slipping. Revox have devised a new assembly to replace thecurrent one.... http://www.vintage-electronics.cc/forsale.html
Posted on Nov 14, 2008
  • 19,396 Answers
    Sergeant:
    Novelist:
  • 196 Answers
Akai GX-95 Reference Master Cassette Deck Owner's Manual
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Apr 13, 2007 | Tascam 102 MKII Single Dual Cassette Deck
185 people viewed this question
 Grubhead
Grubhead
