I DELETE THE D DRIVE OF MY CAMPAQ LAPTOP MODEL NO-PRESARIO C751NR. AND I DONT HAVE THE RECOVERY DISC AND MY COMPUTER IS NOT WORKING PROPERLY, PLEASE SUGGEST HOW & WHAT TO DO?
  • 49 Answers
Depends on what u want exactly:
1. if u want to recover the lost drive, that will take more time to figure out.
2. if u want to get it functional again u can make a recovery cd with the windows XP or Vista software on it,...when u put the cd in it will automatically take u through the setup process,...make sure u turn the laptop on with the cd already in the drive so that it will read it upon boot up, after that it will automatically start asking u what u want to do...
Posted on Nov 13, 2008
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I am delete my one key recovery partion.so i cannot access my one key recovery button....please tell me how can i reactive my one key recovery button tyo restore the operating system...
If you deleted your recovery partition, you will need your recovery discs in order to properly restore your recovery partition. Depending on the manufacturer of the computer depends on how you would access these discs. If they did NOT come with your computer you will need to contact the company and order them. Otherwise you can pop in the first of however many discs into your optical drive (cd / dvd), and when the computer turns on (the first screen) look for something that says "Press F(number 1-12) to access boot menu"
You will then need to reboot your machine, press the F key that it dictates, and then boot from the particular DVD / CD drive that your recovery disc is in using the arrow keys. Please ensure all of your data is already backed up, as using the recovery discs will remove all data on your computer. Good luck!
Mar 03, 2011 | Computers & Internet
How to dwnld compaq c751nr all driver
Here it is.. you'll need to select the operating system. compaq c751Nr drivers Good luck. Thanks for using FixYa.
Jun 10, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop crashed and I want to restore to factory settings and I dont have a cd how can I do it
1) In some cases, you can buy the recovery media from the manufacturer.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
(needs your serial number and often is restricted to purchase during the initial warranty period)
2) Your computer came with a Recovery Management tool which would have allowed you to burn your own. (Too late for this to work)
3) In the Bios see if Disc to Disc Recovery (D2D Recovery) is enabled (Press <F2> during the POST to enter the BIOS.) It will be in the Main section. If it is enabled (or after enabling it - save and exit the BIOS), restart the computer and press <alt> and <F10> simultaneously when the eMachines logo is visible. You should enter the Recovery section and follow the directions. Please note this will reformat your hard drive and you will lose any data that wasn't previously backed up.
I sometimes find it hard to time these startup key strokes, try again until successful.
I hope this helps.
(The D2D recovery information is in a hidden partition (15 GB) on the hard disc, if your computer had the feature. Backing up your data and checking if the hard drive has this partition can be done with a LiveCD of either a UNIX or some other system utility programs (if you have a second RW optical disc or an external hard drive). Using a LiveCD requires hitting <F12> at the eMachines logo to enter the boot menu.)
Mar 25, 2010 | eMachines E620-5885 Notebook
My computer won't start, the creen shows Disk Boot Failure, Insert System Disk and press enter. F10 doesn't work either
it means that you may have a corrupt/deleted windows, check your hard drive if it is working properly, if the hard drive is fine, then re-installation of windows is needed, or if you have a recovery disc use it to repair your windows
Nov 23, 2009 | HP Compaq Presario SR1550NX (PY059AA) PC...
Compaq Presario C751NR
Hi Shynewyork...
Unfortunately, it's as I suspected. Your hard drive is bad or had bad sectors and that's the reason why you are unable to use the recovery disks. How old is your system? Is it still under warranty? If it's not under warranty, the better news is that, you can purchase a new hard drive and at least you'll just be out the price of the hard drive.
Anyway...I can help you with the type of hard drive you need if you want to go that route.
Let me know what you think...
Apr 21, 2009 | Compaq Presario 700 470024-192 Notebook
My laptop crash and not reloadin
type restore ansd wait ,or reinstall from the disk
Mar 14, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
CONFIGURATION FOR A SOUND CARD ON Compaq Presario C751NR Notebook PC XP SYSTEM FROM VISTA
Go to driverguide.com and search for the driver by the sound card make and model.
Jun 26, 2008 | NEC Lavie MX2 Notebook
Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
Jan 28, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
