Question about Dell Dimension E310 PC Desktop
IDE Drive not found on startup
I just installed a DVD drive in my Dell Dimension E310. After startup I got the BIOS screen stating two of the drives not found. These were the PATA-0 and PATA-1 drives for the PRI IDE Master and PRI IDE Slave. I can work on the computer and access internet. It appears that everything runs on the computer except for the CD and DVD drives. I also think the floppy disk drive won't work because the 'A' drive and CD and DVD drives do not show up in the My Computer folder. The device manager does not have the CD or DVD drives but does have the PRI and Sec IDE channels showing up in the IDE ATA/ATAPI controllers section.
  • smolensgc1 Nov 13, 2008
    I have tried different combinations of the jumpers including the one you said to use and have both on Cable Select. The new drive I purchased has a diagram showing which jumper is which but the original CD drive does not show which is which. I assumed that all drives used the same Master/ Slave/ Cable Select positioning for the jumper so I went by what the DVD drive diagram showed for both drives. Was this a correct assumption? Thank You.
  • smolensgc1 Nov 14, 2008
    thanks. Original IDE cable did not work with drives. I replaced cable and all is working fine.
  • 2,427 Answers
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Posted on Nov 13, 2008
  • Rishi Roshan Ali Nov 14, 2008
    sorry for the delayed return.. glad to know its fixed,, and yes most drives have the same settings..
Error code; 00f00:136c IDE device failed; Blank or no media is present in optical drive. Front panel audio and flex bay cable: not installed Onboard or USB floppy drive (not present) Onboard IDE hard...
the diagnostic was looking for media in the CD drive during the test. If the drive works in Windows and reads media or you can boot to the CD drive, then there is nothing wrong.
Jan 07, 2011 | Dell Dimension E310 PC Desktop
The hard drive wont intiialize I think it might be the mother board. how can I tell. it is a dell dimension 8300 computer
If you see the Dell BIOS flash screen, then the motherboard is likely working. Try the drive in another computer to test its integrity.
Sep 03, 2010 | Dell Dimension 8200 AUD System Board...
After startup my PC I got the BIOS screen stating in "Detecting IDE drives...".but it does not detect the drives and also not enter to the further startup configuration.please give a solution of this...
Shut down computer, disconnect from power outlet. disconnect all usb devices on the usb ports and just leave mouse and keyboard connected. disconnect harddrive cable from the motherboard and hard drive and reconnect cable again.
Restart system afterwards to see if the issue was resolved.
Should you have any other questions please just leave a comment.
Cheers~
Jun 26, 2010 | Dell Dimension E310 PC Desktop
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver...
first try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Nov 12, 2009 | Dell Dimension XPS 400 PC Desktop
Won't boot from dvd rom (I'm trying to install Ubuntu Linux)
If your system has one optical drive, press F12 when the Dell screen comes up at boot. then select the drive...
If you have more than one optical drive, the master is the only one that can boot(per Dell).
If the above (F12) does not work, you can try changing the boot order in the BIOS to:
First--CD/DVD
Second--IDE-0 (hard drive)
Third--(any other devices)
Jul 08, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Drive 1 and 3 not found
first off be sure your drives are enabled in your bios
May 17, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
Floppy diskette seek failure
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Dell Dimension E310 PC Desktop Logo
540 people viewed this question
Alun Cox
