Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
E18 error on Canon ixus40 - lens stuck
My daughters camera Canon IXUS40 is getting the E18 error .The lens was open , and it it would not close and the E18 error was showing up, I gently pressed the lens down until it had clicked close, I though this would solve the issue , now it will not open and the error E18 stills shows up when power up and shuts off shortly after.
Is there a fix to this problem?
Thank you!
Richard
    Master:
  • 623 Answers
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Posted on Nov 13, 2008
E24
Canon E24 error means that there is a loose connection inside the camera, or even a broken (cracked) flexible pcb.
Open the camera up and check all pcb connections, especially to the LCD and to the lens assembly. With the camera open, power it up and wiggle each connector in turn to see the effect, but make absolutely sure not to touch any of the flash circuitry as it can give you a shock and a burn (absolutely do not do this at all if you have a pacemaker fitted). You'll need to have a set of jewellers' screwdrivers and an anti-static wrist strap (properly earthed) whilst doing this. If I've lost you already, then it's not a DIY repair.
I cannot be more specific as you spent no time at all to provide exact model details, nor even a proper question, sorry.
Feb 26, 2011 | Canon Ixus30 Ixus40 Ixus 50
I need display for my ixus40 camera ! thank you
The IXUS 40 is called the SD300 in some parts of the world. If you feel confident about doing the replacement yourself, you can order the part from
http://uscamera.com/ck9-1103.htm
Dec 09, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
Date display in photos in IXUS40
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
your date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
May 09, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera got stuck
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Mar 12, 2009 | Canon PowerShot S80 Digital Camera
Error message E18
at my A80 the following Link solved my problem properly.
http://photography-on-the.net/forum/showthread.php?t=5700
Best greets
Martin
Jul 05, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lens is jamed
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 11, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Problem during assembly in reverse order on Canon SD300 (Ixus40)
Not quite sure where you are having the problem with your camera, but there are several places on the internet that can help fix your camera and/or lens.
Here is one listing I found on eBay for you - http://cgi.ebay.com/Canon-SD500-Camera-LENS-BARRIER-SHUTTER-FLAPS-REPAIR_W0QQitemZ260164183646QQihZ016QQcategoryZ64352QQcmdZViewItem
You can email him your model number and he should be able to help you.
Best of luck!
Dec 20, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon IXUS40, rubber(?) seal between lens rings & body keeps popping out
It can be replaced, but requires removing the front face of the camera. Here's an example disassembly. Proceed no further than removing the front face to install the seal:
http://www.smashedhat.com/sd300repair/
Not sure where you could find a replacement other than from another (broken) camera. The seal is mainly intended to minimize sand and grit from entering the camera, but is not necessary for operation of the camera.
Dec 18, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
SD Card capacity and make problem with IXUS40/SD300
Basally, you are not limited with the SD card capacity. It is an "economic" decision only. Sandisk is one of the best companies for it.
Aug 07, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
810 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
