I have Bang & Olufsen T.V. which uses Phillips W76ESF331X44 tube. Can you please advise where I would be able to get hold off one. Regards, Dipa.
ginko
  • 19396 Answers
SOURCE: Bang & olufsen Beovision 7-
Nice TV set. Try first unplugging the tv for ten minutes, this quick hard reset will drain power from tv, and sometimes it solves the problem when TV is freezing on startup.
If this soes not work there must be a service reset procedure.
Posted on Aug 17, 2008
jmeredith
  • 417 Answers
hi,
Im taking a look at your userguide at www.bang-olufsen.com. Im sure your aware of what kind of tv this is, its VERY expensive and complex. Im on a dialup connection and Im downloading the pdf for you, it may take awhile. Okay- find and select ZONES on the remote and choose where the tv is in your house from there your tv will come up with input sources on the screen , choose which input your using and then it should fire up, I recommend going to the b and o website and setting up an account, its free and you can take a look at all the way cool stuff they have.
good luck
J
  • 244 Answers
SOURCE: Hi! Got a bang olufsen mx 3000 tv that just gone
could be the projector bulb is dead. open it up and check the bulb. if it's discolored and burnt looking, you need to replace it. if it's still under warranty, the bulb may be covered- but i doubt it. if the bulb looks good try removing it and re-placing and try again. it may be a little loose, because of thermal expansion and contraction when it cools down. a wee bit of wd-40 can help! i mean, put some on a paper towel, and apply to the threads, or bayonet connector, whichever! if its 'spring loaded', a little wd-40 on the base contact couldn't hurt either! be careful with the wd-40- it's a great contact cleaner, but is flammable!!
so use very little and let it evaporate a little- the bulbs get very hot!
good luck! by the way, the bulbs are not cheap!
Posted on Oct 08, 2009
Testimonial: "great help! "
Grubhead
  • 5348 Answers
SOURCE: I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Posted on Dec 24, 2009
  • 122 Answers
SOURCE: Bang Olufsen doors won't open automatically
unplug from mains,close doors by hand,reconnect mains,does the doors open or can you hear something trying to happen,if so the guide rails for doors may need cleaning/lubricating otherwise the cable drive may be detached(a workshop job).
Posted on Jan 11, 2010
How do I replace the battery on my Bang and Olfsun BeoCom 2 hand set
The battery retaining clip assembly sits inside a groove that holds it in place. Do not try to pry it you'll probably break it into many pieces. Using a retaining spring pliers, insert the pliers two prongs into the two tooling holes in the assembly and squeeze it so the clip assembly clears the groove ledge. It will come out slowly. Replace the battery. Assembly is the reverse.
Nov 22, 2011 | Bang Olufsen Bang Olufsen BeoCom 2 24 GHz...
Bang and Olufsen Beosound 2000 directions
This is described in the owners manual. If you donĀ“t have it, ask here, they can get you every Bang + Olufsen manual
Sep 04, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I recently purchased a Panasonic DVD Recorder Model DMR-EZ48VEB to use with my Bang & Olufsen Beovision 8902 TV. Having set up the recorder the DVD remote control would not work because the DVD...
You said you have the operating instructions, try this,instead of doing the manual entry of your code, try using the CODE SEARCH method for each one....hope this was helpful.....
May 23, 2010 | Televison & Video
Can I wall mount my beosound 4000? Who sells a bracket?
There should be no reason,you can't wall mount your
system. I don't know if there are specifically made
brackets for your particular system,but if you are handy,you should be able to attatch the system to
a shelf,with 2 -L bracket shelf supports.Just make
sure,that you anchor the system to the shelf,and or,
brackets,so it won't be accidentally knocked off.
A very nice system. Be sure to anchor to the studs
in the wall,so it's properly secured. Also,try Crutchfield.com. They might have something easier
to use as a mounting option. Good luck.
Apr 01, 2010 | Bang and Olufsen Beosound 4000 Shelf...
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Need owners Manual
there's a collection of free bang & olufsen manuals for download at http://beomanuals.com, maybe you can find it there.
May 05, 2009 | Audio Players & Recorders
The wire on my Bang and Olufsen has come off
this job can be done from the front but it is very fiddly so suggest youprevent hair loss by taking to b&o repairer.
Feb 06, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
