Question about Lexmark P4350 All-In-One InkJet Printer
Paper does not feed completely properly.
Symptoms include any one/or combination of the following:
-Document does not print squarely on page
-Document is off center (top-to-bottom) because paper did not feed immediately
-Paper does not feed at all; error message indicating paper jam or printer out of paper.
Hi all
The usual problem with this combo is the 1st paper feed roller,this becomes "glazed" with the additives in modern papers.
To gain access remove the power supply remove 1 screw holding its retainer in position and remove it.
Remove the white gear on the end of the feed roller shaft (it is fiddly) and then withdraw the whole feed roller assembly.Clean the roller with meths or alcohol making sure that you get rid of all the rubbish and that roller feels like rubber again.
Reassemble and away you go.
Cheers Davwiz
Posted on Dec 02, 2008
  • markatcmk Jan 29, 2011
    does the gear wheel just pull off? can't see how to remove it
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the error still exists then its the problem with rollers it needs to be serviced..
Good luck..
Posted on Nov 23, 2008
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
Print tow side on Canon LBP 800 Laser Printer
Hi
I have found both a Getting Started Guide here:
http://dl.owneriq.net/6/6b8eae44-71d6-4f7d-a01c-369b4426c2f6.pdf
and a User Manual (more comprehensive) here:
http://www.printerrecharge.com.au/manuals/Canon%20LBP-800%20User%20Manual.pdf
I've also looked through them and there is no mention of duplex printing capability, nor does the paper path shown in the manual show it as possible. The only way to double-sided printing is therefore manually. To do this
Print the odd numbered pages of the document (in properties box).
Remove the paper from the outlet and turn it over .
Replace it in the paper feed tray with the blank side facing you.
Print the even numbered pages of the document.
Please be careful to make sure that page 2 prints on the other side of page 1 and so on through the document, as it is very easy to put the one side printed pages in the feed tray with the last page, in the position to be printed first causing a complete waste of paper. Also leave the one side printed paper for a few minutes before refeeding as doing this too quickly can result in a paper jam.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Canon LBP 800 Laser Printer
Some pages offset printing
You need the paper feed tires replaced.
Feb 17, 2014 | Xerox 5500/DT Laser Printer
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Lexmark P4350 All-In-One InkJet Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
