Question about Acer Aspire T310 PC Desktop
My pc won't work!
When the computer is turned on, both the on and standby lights stay on, there is a continous whirring noise and the monitor is blank and stays in power saving mode. please help!!
    President:
  • 2,961 Answers
Assuming you get 2 beeps on boot up, take the side off your pc and see if the whirring sound is coming from your hardrive, if so you may have a damaged sector on your hardrive where the boot sector is. If you have a Windows XP disc come back here, if not you need to take your hardrive to a friends pc and set your hardrive as the slave drive before connecting up. When booted up go to My computer and right click on your hard drive (could be 'D' drive or 'E' or 'F')depending on other pc. Go down to properties then tools tab and click error checking and let the system check for errors and automatically repair them. Your rating is importanat
Posted on Nov 15, 2006
SOURCE:
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
My lap top was working fine yesterday , but when i went to turn it on today the startup said to use "run in safe mode " or others options similar to that , i chose one , & it still didn't...
Hi, sorry to hear you are having problems. 1. Start up your desktop as normal but as soon as it starts keep pressing the 'F8' key. 2. You will have a black background with white writing on and lots of options. 3. Use the up and down arrow keys and select last known good configuration, then press the enter key to select it. philswift_4.jpg
Your computer should start up. If you have a blank screen, do you hear the fans whirring and see lights on the front? If so then your computer works but is not sending s signal out to the monitor. Check all cables to make sure they are securely connected. If you still have no image. Swap your monitor for a friends one that you know works. This will test if it is your monitor that has failed. If you see an image on your friends you will need a new monitor or new monitor cable. If you do not see an image on your friends monitor and your PC has lights and fan whirring then you need to get a new graphics card. If you have no lights and no fan whirring it is outside the scope of this and we need some more information as it could be 1. Failed power supply 2. Failed memory 3. Blown motherboard 4. Failed processor
Please report back with answers to 1. Do you hear fans whirring? 2. Do you see a power light/led light up? (in example pic it is green) 3. Do you see the HDD (Hard Disk Drive) LED/light flash at all? philswift_5.jpg
Many thanks for your information
Phil
Dec 04, 2010 | Computers & Internet
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Blank screen after turning computer on
Sounds like onboard video might have gone out. 2 suggestions, if the system is still underwarranty, send in for repair. If not, suggestion would be to open the case, and confirm type of slots AGP, PCI, PCI Express, and purchase a video card on the type to install.
Jun 01, 2009 | Dell Dimension E521 PC Desktop
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Toshiba satellite Dead
Try to push and hold the power button. It more than likely went into hibernation/sleep mode. If this does nothing then remove the battery and charger, then put the battery back in and plug it in and see if this does anything.
Jan 05, 2009 | Computers & Internet
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Acer Aspire T310 PC Desktop Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
