Question about Dell PowerVault 100T DAT72 DAT Tape Drive
Wont accept cleaning tape
My drive ( dell_powervault_100t_dat72_dat_tapedrive)wont accept the cleaning tape, it keeps spitting it back out, the tape is a dds cleaning tape but lists a dat72 drive as one of the drives that its compatible with.
Any ideas
  • Anonymous Nov 20, 2008
    I have the same problem as you have...
    We need the solution of this issue...
    Please help us
  • emmerpitt Nov 20, 2008
    i´m the same problema with my dat72,.
    when i put in the tape cleaning it last 5 sec. to return it back, and the led of clean doesn´t light on
    what can i do for that?
  • 73 Answers
Make sure there are no pending jobs on the drive, if the drive is expecting a tape and gets a cleaning tape it will spit it out. Also, has the cleaning tape been used a lot? They have a limited life cycle and if they have exceeded their max uses they may not work.
Posted on Feb 08, 2009
    Scholar:
  • 74 Answers
Cleaning tapes only have a few uses (about 20 usually but check the box on a new one)
If the DAT72 spits it out very quickly
1) the cleaning tape is expired
2) the drive doesnt need cleaning
3) the drive has a problem loading tapes
if the drive is knackered i suggest www.tape-drive -repair.com in the uk or sanworks in the states
Posted on Aug 28, 2009
The head inside the drive is dirty or worn. You will need to have a technician open the drive and manually clean the head or replace the head.
Tony L.
SanWorks, Inc.
www.sanwork.com
Ph: 714.434.2629
Posted on Mar 30, 2009
Actually for this SPECIFIC DAT72 drive you need to download the most recent firmware update. That resolves this issue. Take my word on it I just repaired this exact issue roughly three weeks ago.
Posted on Jan 11, 2010
In my experience single tape drives are doing exactly as you say.
They take the cleaning tape, clean the drive and spit the cleaning tape back out. This doesn't take that long.
But as MBarr also mentioned, if the cleaning tape was in use a lot then it could be time to buy a new one. Cleaning tapes last about 20 to 50 cleaning cycles (depending on the type of tape and the manufacturer).
Posted on Feb 19, 2009
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Constant Cleaning of new PowerVault 100T DAT72
Tape drives do need cleaning frequently and the 'auto clean' facility may not be enough. The problem is the continuous shedding of oxide needs cleaning right off and the auto system may not be enough. What you need is a back-up Drive. and the out of service drive needs physically stripping down to clean all off using a soft brush and where appropriate coproponal alcohol
Posted on Jun 14, 2007
  • 74 Answers
SOURCE: Dell dat 72 drive will not accept a tape
power off and on the tape drive
Inset a NEW Fresh out the Wrapper cleaning tape and see if that works!
Sounds to me like your existing cleaning tape has expired
If that fails then there could be a problem with the loading mech which is where you will need to send it away for repair.
Try www.tape-drive-repair.com for this as they are not expensive
Posted on Aug 24, 2009
SOURCE: Dell Dat 72
I did some checking on Dell's site and noticed there is a firmware update dated 4/18/2009. One of the issues it addresses is excessive cleaning light issues. I am scheduling a maintenance window with my client and will see if this fixes this issue.
Posted on Oct 23, 2009
Lto110T tape drive will not spit out tape... error code 6 thanks
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/ultriumgen2ug.pdf
Chapter 6. Examine the tapes before inserting them into any drive or robotic environment to make sure the leader pin is present and properly clipped in (page 13).
Aug 17, 2011 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Cleaning light always on
Perform the cleaning action using a new cleaning tape. It is not recommended to clean the tape over and over again, if the cleaning light is still ON. Contact the vendor and get it sorted out.
Please coem back and rate the solution if this turns to be helpful for you.
Thnx
Mar 22, 2010 | Dell PowerVault 100T DAT72 DAT Tape Drive
The
Clean the drive 5 times in a row with a non expired cleaning cartridge
Nov 16, 2009 | HP Compaq StorageWorks DAT 72...
Dec 09, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Dell Dat 72
try a different Cleaner tape, they dont last forever..
Jul 24, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Operating System question
I don't KNOW that this will work, but what I'd reccomend is that you try using the drivers for windows 2000 on your windows XP machine
a list of dell drivers and support for the powervault is here:
http://search.dell.com/results.aspx?s=biz&c=us&l=en&cs=555&k=powervault+100T+driver+XP&cat=sup&x=0&y=0&p=1
Mar 29, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
DAT 72
here select your OS and then the latest firmware
Mar 02, 2008 | HP StorageWorks DAT 72i DAT Tape Drive
Jun 13, 2007 | Dell PowerVault 100T DAT72 DAT Tape Drive
Dell PowerVault 100T DAT72 DAT Tape Drive Logo
2,111 people viewed this question
Alun Cox
