Question about Epson Stylus Photo R200 InkJet Printer
Can not print on to cds
I have an epson R230 when I try to print on to a CD the tray goes in then comes out again then tells me the CD/DVD tray not set correctly
  • WHATDOIDO Apr 14, 2009
    i've tried all kinds of solutions and mine never worked once. but some say you can gently nudge it in when it pulls the tray in to print. this is a common problem. maybe they dropped them during transit...
  • 42 Answers
I have R265 ... make sure the tray is set up in the corner and aligned properly. and check if perhaps there's a corner of the tray missing due to an accidental damage or something and the lases senses it's not there, which causes the printer to think it's not aligned right
Posted on Feb 22, 2009
How do i print on a CD?
sorry to inform but you dont print on CD.
You print on paper and then paste it on CD :-)
That's called "label" printing.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Printing problem
printer does not print with red light
Jul 15, 2009 | Epson STYLUS R230 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Iepson stylus R230
This occurs if the CD/DVD tray is open. Check if the tray is in place and try again.
Apr 23, 2009 | Epson Stylus Photo R200 InkJet Printer
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson r230
hello babu,
the problem is not with the printer, problem is with your general knowledge, to print on cd/dvd surface means you have to stick the sticker (cd label sticker) on the cd, then put the cd on the printer to print.
bye bye
hope u will soon understand......
Jun 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Will not print cd covers
Describe what YOU call CD covers? There is an anomaly here. Are you simply printing onto a4 paper for jewel case inserts or do you mean actually printing onto the CD.
Jun 16, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R200 InkJet Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
