I cleaned a cd and the message code "1300"appeared on the player and a screen display indicates the disc is dirty. I cleaned the disc and still receive the same message code and screen display. I repeated cleaning with no results.
Be careful how you use this, but u can utilize canned air to blow out the debris from your player.
get a laser lens cleaner kit from walmart or something, it will cleans your laser lens inside the dvd player for you, if the canned air and laser lens cleaner doesn't work, your last resort is to completely unplug the player to see if it resets itself, if none of those works i would turn the player in under warranty or take it back to the store.
After working great for years, my dvd player suddenly won't turn on. When I press power, the player...
(More)
After working great for years, my dvd player suddenly won't turn on. When I press power, the player emits a short "ehhnnnn!" sounding buzz/beep, and the light switches back quickly from green to red. It won't turn on, the dvd won't eject, etc. So far I've tried replacing the fuse, but now I'm all out of ideas and could use some help. Thanks!
my sony dvp-ns315 has a power light flashing red and green intermittently, if i hit power over and...
(More)
my sony dvp-ns315 has a power light flashing red and green intermittently, if i hit power over and over it sometimes works fine?
disconected my non working yamaha and hooked up this sony and i used the same conponet cables and i...
(More)
disconected my non working yamaha and hooked up this sony and i used the same conponet cables and i get picture but no sound than i tryed with rca cables same proble
