Question about HP Compaq nc6000 Notebook
Power goes off
When i turm my notebook , its start up but suddenly after 10 secound power goes off and computer is off . i also check battery and other power cable but everything is ok.
    Problem Solver:
  • 11 Answers
1. Your heat sink (keeps CPU cool) may have dust built up on it causing the laptop to overheat and shut down to avoid damage.
Try a can of compressed air ($7.00 Wal-Mart) shoot air in all the vents on the side and under the laptop (do this outside or someplace easy to clean up)
2. Your fan to keep things cool may be stuck (the cleaning with compressed air could fix that) OR it could be broken. When you turn on your computer SOME fans power up this will let you know if it works (some only come on when needed) if your fan does not come on at all you may need to change it. You can Google laptop fans to find a replacement fan and install it yourself.
Good luck My Computer Guy
Posted on Nov 13, 2008
My wife has a disco3 tdv6 hse 2007 with just 74000 miles The egr light remains on after starting All else ok and performance not affected Does little mileage with no motorway Can I rest and how?
yes you can reset by disconnecting battery cable for 10 secound, but you might want to check the vacuum and sensor for egr valve not much can go wrong with it. if the o2 senor goes bad before now it may have carbon build up . pull out and clean with tooth brush. 86 cent gasket. EGR sensor adjust fuel use, there before your gas milage will get better.
Feb 23, 2018 | Cars & Trucks
Sudden loss of power
Are you sure the battery is being drained during this process? That would be a major draw from something, but then you said "...suddenly full power again,". It sounds more like a connection or a terminal working loose at times, not able to pass normal voltage. You sure need a voltmeter, my friend.
I think I would want to have that new alternator tested again, just to make sure it is not defective. A lot of aftermarket parts are turning up like that. Did you replace the alternator and battery because this condition was present? Do you know your battery cables and ground points are all good and secure, and corrosion free? You might want to double check all the grounds you can find- the battery negative cable, the engine to body strap, or cable, maybe an engine and computer harness ground point-look around the top of the engine for a ground wire coming out of the engine wire harness and going to ground at a nearby bolt. Also check all alternator connections.
If you have to keep looking, look at the power side of the power distribution scheme. From the battery, power goes to the Power Distribution Center, maybe called a junction box or junction block...it is where the fuse and relay block under the hood receives power, both from the battery and the tie-in from the alternator, and then distributes it to the major circuits for the car. With all your symptoms, it sounds like the problem is not far from the battery in the power distribution. Sayeth Dr. monte. Good luck.
Sep 14, 2014 | 1994 Hyundai Excel
My laptop will not power up
Rule out: Water damage. Rule out, power supply, damage to cord, damage to plug end that fits into the computer power port. Check computers power port for bent female contacts. Battery can also be a problem. Some laptops will not function if the battery has lost charge or is dead. If none of the above, a CPU going bad or hard drive dying, will also cause the computer to fail when energizing.
Vest you have a computer technician look this over.
Feb 17, 2018 | HP EliteBook 6930p Notebook PC
Lap top will not start up
take it to service center before you try anything else and the problem gets worst
Nov 22, 2008 | Lenovo 3000 N200 Notebook
Vaio will not turm on
you will most likely need to replace the dc jack, which is the port where your charger plug plugs into...
To test if your dc jack is bad... Remove the Battery, Plug the Power cord into laptop then attempt to power on... If no lights turn on, no fan spins.. your DC jack is bad...
DC Jacks Cost $6 to $10 but you need to find someone experienced to replace it, or you might end up with a dead motherboard as well..
Oct 14, 2008 | Sony VAIO PCG-V505DXP Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
Dell inspiron 600m idle battery
the battery has gone bad and needs replaced, also check manufacturers web site to see if the battery is on recall, may be get it for free.
Nov 12, 2007 | Dell InspironTM 600m Notebook
HP Compaq nc6000 Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
