Question about Belkin Hi-speed USB 2.0 5-Port PCI Card [ F5U220 ] (109213) Serial Adapter
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Installed above card. Device Manager reports no problem. When copying files to external USB 2.0 hard drive, or USB 2.0 flash drive, saving will begin and then computer freezes. If copying from external hard drive to C drive, no problem and saving is at high speed. I have disabled the onboard USB and rebooted but the result is still a computer freeze. I have used the Microsoft drivers and then the Belkin drivers but the result is still a computer freeze. Checking the error log, I always find an entry:- The NEC PCI to USB Enhanced Host Controller service failed to start due to the following error: The system cannot find the file specified. This error report appears after the computer freezes. It also appears after bootup even though I have not used a USB device. If I revert back to the onboard USB 1.1 there is no problem in using the external hard drive or any other USB device.
  • Brad Brown Mar 12, 2017
    Hi John Barker, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make and model of computer and os version
  • 4 Answers
I think all these people are wrong. Using a belkin pci card will be the problem. All USB ports are 2.0 driven even on very old machines. Modern PCs use the oldest usb all the way upto the newest and are all compatable. They have to be for compatability issues. Only a few PCs I've seen use 1.0 usb. They're still compatable just the transfer rate is slower. Belkin in use strange drivers that Windows just doesn't run well with. The amount of issues to do with sound stutter to blue screens of ***** and even performance issues were all due to belkin wireless adaptors and there drivers. I think all you need to do is pull the belkin pci card and buy a 4 port usb hub that fills a slot in the rear and plugs into one of the internal sub headers on the motherboard usually along the bottom either yellow or green. Old boards may be black. I think personally if you ditch the pci card and buy a 4 port usb hub off eBay for about 1£ you will be fine. No drivers to install and they are plug and play
Posted on Apr 26, 2017
Usually there is only 1 usb that can handle usb version one behind computer and you might need to consider updating the os to win xp service pack 4
  • JAKOB LIN Apr 26, 2017
    usually there is only 1 usb that can handle usb version one behind computer and you might need to consider updating the os to win xp service pack 4
    Sergeant:
  • 248 Answers
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Posted on Apr 08, 2017
SOURCE:
rahul26485
  • 611 Answers
SOURCE: keep getting i/o error message
if you using throught usb port then chnage the port and re-connected hard drive
Posted on Jun 21, 2008
SOURCE: Belking wireless adapter install
Download the proper drivers from the belkin.com/support website,the issue will get fixed(download the manuals also)
Posted on Sep 25, 2008
SOURCE: WD My Book 1TB not recognised by belkin modem router USB storage
This is not as complicated as it may sound. You don't need the manager. Bring up the "run" window (XP - Start - Run / Vista Alt-R). Enter the following address [\\192.168.2.1] press enter. The drive will show up. Right click on it and select Map Network Drive. You can then uninstall the useless program from Belkin.
Posted on Apr 14, 2009
bob_computer
  • 3153 Answers
SOURCE: I just installed usb 2 pci card in an old win98 pc
That is a common thing with the early win 98 os and newer hardware.
You really should consider an upgrade to at least 98SE or even WINDOWS ME.
The machine will struggle with USB 2.0 and you are open to a whole lot of little glitches
Posted on Aug 20, 2009
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
Tip
Make ESET NOD32 Anti-Virus Auto Scan Flash Drive
Everyone doesn't want computers infected with a virus. The question is, where the virus entered into the computer. There are two possibilities, may be infected from the Internet or external device (flash drive, memory cards, external hard drives, etc). Flash drives are external devices that are often used. When we insert the flash drive to the infected computer, flash drive will be infected with the virus. In a flash drive that is infected, will form the autorun.inf file. Autorun.inf files will work automatically, every flash drive is inserted. Setting the default operating system is windows autorun when inserted an external device. Autorun windows, used by the autorun.inf, to enter into the computer. To protect your computer from viruses, there are a few things done:
1. Update anti-virus
2. Setting anti-virus in the guard position
3. Turn off windows autorun
4. Make anti virus auto scan flash drives
Turn off autorun Windows
Win Xp : Press START - run - regedit - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer - NoDriveTypeAutoRun - Value Data - Type = ff - OK
Win Vista / 7 : Press START - Control Panel - Hardware and Sound - Autoplay - uncheck "Use Autoplay for all media devices" - SAVE.
Using software USB Safely Remove. Open software USB Safely Remove - click View - Options - Global Autorun - After device plugging - click Add process to launch list - click browse, open directory C:\Program Files\ESET\ESET NOD32 Antivirus\ecls.exe - Open - then double click the drive letter, to add parameter %DriveLetter% - then, on the tab File name and parameters, write /log-file=c:\report.txt /log-rewrite /aind - OK. Then. click Add process to launch list - write "C:\report.txt" - then unchecked "Wait for the process to finish" and "Launch the process for drives only" OK - FINISH.
on Sep 26, 2011 | ESET NOD32 Antivirus
Genx flash memory
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Note: Connecting your USB external hard drive into a non-powered USB hub can cause a lack of enough power to operate the external drive. Instead, plug it directly into your computer.
Sep 29, 2013 | Electronics - Others
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
It is not detected by any computer
Check you have usb 2.0 drivers installed on the computer, go my computer and right click on it, then go to device manager and for universal serial bus drivers click on the '+' sign and see if have 'Usb2 Enhanced Host Contoller' if you dont you can download the driers here: www.softwarepatch.com/utilities/via-usb2.html.
If you are still getting the problem and usb2 drivers are installed the usb flash card must be corrupted.
Jan 24, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Toshiba 60GB USB 2.0. Portable not recognized in my computer
Check you have the usb 2.0 drivers installed on the computer. You can check this in device manager in the properties of my computer icon. if you havent got USB2 enhanced host controller you havent got the driver.
You can find the Drivers and how to load them at this site:
www.softwarepatch.com/tips/usb2-driver.html
Jan 22, 2010 | Toshiba 120GB USB 2.0 Portable External...
HP Pavilion laptop won't detect my External SATA Hard drive
Thanks,
Sounds like you have a proper adapter. Also thanks for the Vista info, although that's not helping it did rule out one major possibility.
Unless you have another drive to try on the adapter, or another adapter to try with your drive it will be difficult to isolate which one is the problem.
First thing to do is, with the drive connected to the new computer open your start menu, hover the mouse over Computer, right click on Computer then select Manage from the grey menu.
When the managment console opens click on disk management on the left then maximaize the window size. Wait a moment for windows to assess the drives in the system then scroll through the list. You should see your windows drive(it will have one large partition and usually one small one as well, a DVD drive and up to 5 media drives(they represent each type of memory chip your card reader can use.
Now look for a second entry similar to your boot partitions drive on the lower half of the screen(C: is boot). If the external hard drive is listed there you're in good shape, report back with all the details in the row that drive is on starting with the disk number
ex: Disk 0, Basic, 80GB, Online, C: 70GB, NTFS D: 8GB, NTFS
If the drive doesn't show up on the disk manager, go to the device manager on the left above Disk Manager, Expand Both the disk Drives section and the USB section and report back what is listed in each. You can ignore the entries in USB for USB host controller, just report them as there, how many and if they are listed as USB or USB2.
Reply back when you have this information and I will take you through the next few steps acording to what you find.
Crankstart
Jan 08, 2010 | Computers & Internet
FREEAGENT 250 GB AND USB2 NOT CONNECTING
Most of the time if you get an event 51 error you will need to reinstall drivers associated with that device to fix it. I would delete the device from device manager, uninstall any software that you installed for it, then restart your computer and reinstall the software. I would do this for both the card and the drive. I would also run Windows update to see if it finds any other drivers that you do not have installed. If that does not work it is possible that the card and drive might not work properly together. The only other thing I can suggest trying is reinstalling windows
Nov 14, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Won't function
Firstly it sounds as if the drivers aren't loading properly, right click on your drive (right click my computer> properties> hardware> device manager). Look for your external drive, rightclick and click update driver and force it to look in your cd for driver files. Secondly make sure you are connecting to a USB2 port, as it may not recognise the hardrive.
Oct 25, 2006 | Plumax PM-350U2-PCS V4 Silver Slim USB 2.0...
Computers & Internet Logo
169 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
