Hi, I have a 26" Matsui LCD flat screen tv and it has a long narrow blue line one third in from the left running vertically. We can live with it but would like to know if it's correctable/fixable.If so approx. how much? Many thanks
  • 3Dviewer Nov 14, 2008
    thanks for the advice. I took the back off and checked all the connectors that I could find without getting into the 'guts'. I paid particular attention to the circuit board with multiple plugs that I felt might be the main board for the screen.I also vacuumed all over the boards etc. Unfortunately the blue line is still present on this t.v. so that didn't work. Very much appreciate the advice though and enjoyed 'getting stuck in' : )
    So is it likely to be the screen or a circuit board. Any idea how much? Are the parts easily available?
    NB I don't think it's a 'projection television' just a LCD HD TV
    Thanks Dan,
    I'll probably live with it as the TV was bought at auction 'sold as seen' but wasn't switched on at the auction rooms and had a large sticky area on the screen.This was due to an old sheet of protector being left on. The plastic came off easily. This obviously put buyers off as the TV cost £6 UK or $9 inc taxes !! at that price I would be impressed if the viewing area was a thin line and the rest of the 25.99 inches was blue : )
    Thanks again
  • 4,234 Answers
This can be an indication of a defective LCD panel or just a bad connection to the panel. If the unit is no longer under warranty, open up the back and reseat all of the cables and connectors. Sometimes because of the extremely low level of the signals that are inside the unit, a little dust or dirt can make a questionable connection fail. Update this with your results. If the unit is still under warranty, request warranty service.
Dan
Posted on Nov 13, 2008
  • ABRsvcs Nov 14, 2008
    It is not a projection, just an LCD. Unfortunately there is no way to determine whether the problem is a logic one or the panel itself. My experience suggests that it is the panel. If so, the replacement panel could easily cost almost as much as a replacement set. Check around in the area for a service shop that works on your make of set and get an estimate on the panel cost.
    Dan
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
I have a line running thru my tv
vertical(up/down) or horizontal(left/right)? color/white? when you tap on the top of your tv does the line go back to a full screen? could be a makers defect.
Aug 22, 2011 | Samsung LN-S2651D 26 in. LCD Television
The screen is blue with vertical dotted white moving lines ... menu options are psycodelic in color
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem, and do take care in handling the problem....
Jul 06, 2011 | Sylvania 6626LCT 26 in. LCD Television
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
I have a vertical blue line....left of center
If it is narrow you have a dead pixel problem. If so contact HP for advice. Three year warranty on screens and they usually swap out for failures. Very common problem.
Jan 23, 2008 | HP f1905 19" Flat Panel LCD Monitor
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
