Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
I have a samsumg WA13R3 wash ing machine error cames up dE
I have a samsung WA13R3 topload washing machine error de please help
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
techbuster
  • 5081 Answers
SOURCE: we have a samsung j845
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Posted on Aug 30, 2010
My samsung washing machine model SW50V3 showing dE error after its full of water, its not spinning at and even not draining as well, plz help thank you.
Did you go to Samsung site and inquire re the significance of the DE error?The machine is telling you where the problem is. Use the info and check it out.
Sep 17, 2017 | Samsung Washing Machines
What does DE in red mean on a samsung DV400 washing machine
There is a door problem.
The following link may provide helpful information.
One can also search the internet using the following:
"DE error code, Samsung DV400"
Jun 02, 2017 | Samsung Washing Machines
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
Nov 20, 2016 | Washing Machines
I've got a samsung top loader washing machine, it's giving me a DE error code. The door is closed and the message only comes when it's about time to spin
DE = Door Error
• Check the Door-Lock SW terminal connections and contacts.
• Bring the probe of tester into contact with two terminals of Door-Lock SW.[dE Error]
What Samsung is attempting to say is: check the door lock assembly, your machine will not spin if it "thinks" the door is open...
May 02, 2016 | Samsung Washing Machines
I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
My washing machine is displaying an error code ... - Samsung
www.samsung.com/my/support/skp/faq/1033803
Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
Aug 06, 2015 | Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
Error on screen if load bigger - DE
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks
May 24, 2010 | Samsung SW62ASP Top Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
167 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
