Question about Acer Computers & Internet
Laptop will not start up except for 1.5 seconds
  • deadlydec Nov 15, 2008
    fan& power light comes on for nano sec only .just no life at all.
    Habit-Forming:
  • 17 Answers
Haw you try to start up windiws in the safety mode. You press F8 before windows start up , and you chose safety mode. I had a ibm with the same problem , there was the hardrive som whas faulty.
But if you can try to press F8 , ans se if you can start up windows. a another solution are to reinstall windows , but if man have many things on the computer man dont want to loose , it are the last solution.
Did you get some error mesage on the screen?
Posted on Nov 14, 2008
  • Jan Jensen Nov 16, 2008
    That can be a bios fault . All computers start up the bios first . In 98 i have a digital celebris with a bios fault , then the computer dont start at all. I change the bios with a new one and the computer its was ok. You must go to a data shop and hear if they can change the bios for you. Bios are a small piece on the moather board , and when man change it man must install bios software for the new bios.
    Go to the data shop where you buy the laptob and ask if they can test the bios on your labtob.
    A another fault could be the battery ore the el power adapter , but i would check the bios first.
How do I reset my SMC barricade g router?
hi Eric,
To Reset the newer Barricade Router, use the RESET button on the Router. It is found on the rear panel (except 7004ABR/7008ABR, where it is found in the front). It's a small pinhole blue button. Use a paperclip / pen / pencil to hold in. Reset can be done in following ways. If you find Power LED blinking, then it indicates a successful RESET......
Procedure 1 -
Unplug all the cables except the power cord.
While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Procedure 2 -
1 - Unplug all the cables except the power cord.
2 - While the Barricade is powered ON, Hold the RESET button for 5 seconds.
3- While holding the RESET, turn OFF the power to the Router.
4- Continue to hold it for 5 seconds, then turn ON the power to the Router.
5- Wait for another 5 seconds and then release the RESET button.
Procedure 3 -
1 - Unplug all the cables except the power cord and Power ON the Router.
2 - Hold the RESET button for 3 seconds.
3 - Release the RESET button for 2 seconds.
4 - Continue Steps 2 and 3 for Four more times.
Sep 03, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
How to clear and load cmos default bios parameter for a Aspire 5630 modle no. BL50?
Two methods;
A)
1) Remove ALL power to the laptop, except the CMOS battery.
Remove the AC adapter (Charger) and Battery.
2) Press the Power On button in, and hold it in for a full count of FIVE seconds.
Let go of the Power On button.
Do this procedure TWO more times. (Important)
This procedure clears CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
Reinstall power. Install the Battery FIRST, then the AC adapter.
B)
Go into BIOS Setup.
As soon as you press the Power On button, start tapping in 2 second intervals, on three keys at the SAME TIME.
Press all 3 keys at the same time.
CTRL, ALT, and ESC.
No?
Hold the Power On button down for 10 seconds to turn the laptop off.
Wait 30 seconds, turn the laptop back on.
As soon as you press the Power On button start tapping on the F2 key.
(Tap in 2 second intervals)
When in BIOS Setup look at the main page, and towards the bottom.
Here you will see an F key listed that when pressed, will revert BIOS Setup back to the factory default settings. (Generally F6)
C) Remove all power from the laptop.
Lay a towel on a table, and lay the laptop upside down on the towel.
Open the Memory Compartment Panel, and remove all ram memory modules. ('Stick')
Located towards the middle of the ram memory compartment is the J3 jumper.
There is a J3 with a square line going around it.
This jumper is used to clear any settings made, and will go straight back to all factory default settings.
In otherwords if someone set a BIOS password, the J3 jumper will remove it.
Factory setting for BIOS password is no password.
Regards,
joecoolvette
Oct 09, 2011 | Acer Aspire 5630 Notebook
Computer runs normal except for black screen ;but when i attach it to my tv i can see the screen display
your lcd is caput...................
buy second hand 1 from ebay.
can be swaped in matter of 20 mins...........
cheers
Mar 26, 2011 | HP Computers & Internet
My screen is blank except for the arrow. I've rebooted several times but nothing comes back up. The lights at the top, i.e. DVD, play, ff, stop, mute and volume, are on and won't toggle.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
The problem with my HP nx9010 laptop is that, after my laptop opens the icons on my desktop starts blinking. The mouse wont let me click on any other icon on the desktop except the first one that is My...
Aug 28, 2010 | HP Compaq Business Notebook NX9010
I have a Model M40X that only turns on power light after switching on then starts the fan for 4 seconds hd and dvd lights just flash once then nothing no boot screen just the power light. 1 out of 25...
There are many things that can cause this type of symptom.
Is it failing on battery only? May need a new battery.
is it failing when plugged into the power adapter?
The adapter input jack will fail over time and need to be replaced.
There is considerable mechanical stress on this part, and It will fail where the jack is soldered to the circuit board.
Internal circuits can fail. Maybe a new laptop will be cheaper than repairing this one.
Oct 05, 2017 | Toshiba (K000002020) Motherboard
Will power up for only 1 second.
defactive main bord .if you hit on bootom of laptop or push hard may start working i hope this work
Jan 09, 2010 | HP Pavilion dv9205us Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
