My Philips Plasma keeps shutting down then starting up again
  • Fritz911 May 01, 2009
    I had the same problem and it took me about a year and a half of calling Philips almost every day complaining. They replaced my television and the new one had the same problem. It took more than 6 months of complaining to them again before an electronic company came and took the tv. They told me that Philips know about the problem and there is a fix. After they repaired it the turning off problem never came back.
Did you try updating the firmware? Many display units in the store did this and I've read about it on-line. Mine came with the latest firmware which fixed this issue. Never wasa problem for me.
Posted on May 08, 2009
    Master:
  • 623 Answers
There is maybe an information in the instructions manual :
http://www.my-instruction-manual.com...
Posted on Nov 13, 2008
I've got a Philips 221V mnitor and it diplays:
boot your pc , keep on pressing f8 key then select safe mode option, remove the graphic driver, then shut it down, then again start install the graphic driver
Jul 28, 2011 | Philips C.927126 Monitor
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF9630A
Go to philips website and download the latest firmware and install via usb. The fw corrects random power on and offs. If that doesnt fix your problem, the tv is going into error protection mode do to a voltage problem detected by the power supply.
That will be hard to diagnose as everything will test ok as it works before shutting off. The best way is to run the set and use a temp gun to find out whats overheating and go from there.
Aug 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
My plasma shuts down ..
Since it is still under warranty, it is best to get a replacement rather than attempt a DIY. I would suggest you get yourself a surge protector too..Seems like the issues you are experiencing is due to fluctuating voltages..
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Philips Magnavox 42MF521D/37 Television
It keeps intializing
Install and run the Philips Device Manager.
Press and hold the [VOL+] button on the player whilst connecting to the PC.
Philips Device Manager will show the device connected in repair mode. Release the [VOL+] button and follow the on-screen prompts.
This will format the player and re-flash the firmware.
Disconnect the player when finished, and re-start it. It should briefly show initiallizing and then shut down.
Re-start the player again, and it should show "updating", then start up.
Occasionally this will cure the problem. If it doesn't try it 2 or 3 times.
If it still doesn't work, then unfortunately you will have to take it back, as there is no other known cure.
Mar 14, 2008 | Philips SA6025 Digital Media Player
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Televison & Video Logo
Top Televison & Video Experts
